Pages: 1 2 [3]  All   Go Down
Author Topic: Which windscreen ?  (Read 15257 times)
ajsphead
  • North Somerset
    • Omega 2.2 DTi estate
Re: Which windscreen ?
« Reply #30 on: 19 September 2018, 07:33:44 »
7 parts would be the 4 frame pieces, two rubber pieces and the screen... effectively a complete screen assembly :y
Agree with DG. 7 parts total including the screen. 2 fitters also helps. The point to watch out for as also said above is the top corners of the trim strip not sitting flush with the body and screen. The third set of fitters I had were aware of this and one of them told me the technique for getting it right as apparently there is one. Sadly I've completely forgotten what it is.
When the screen is off have a good look around the car body for rust particularly the seam where the inner wings and scuttle join. This is your opportunity to fix anything brown and fill in any defects in the paint caused by slap dash previous efforts at removing the screen trims.
Paddy Flannery
  • Hertford, Hertfordshire
    • 2003 2.6 V6
« Reply #31 on: 19 September 2018, 07:58:35 »
Agree with the above. To their credit Autoglass sent two fitters each time and I have to say that when it was finally fitted with all the GM kit, it fitted perfectly and the guys did a very neat job inside and out. No excess sealant, no bits left over the car or on the ground and when running, no wind noise or leaks.
The key to all of this is to politely insist on genuine parts as the Omega simply refuses to allow pattern parts to work in the windscreen area.
« Reply #32 on: 19 September 2018, 10:50:35 »
The knack, as I understand it, is to fit all the frame and trim to the screen. Ensure that the scuttle is secure in the correct location, and that the body is spotless and rust free/smooth. Make sure that the sealant bead is just right... Too much and the screen will stand proud, too little and it stresses the rubber trim where it clips to the frame*. Glass surface 1mm below body surface rings a bell, but I can find nothing to confirm it... Even the Thatcham Body Repair manual doesn't specify anything beyond bonding part number/equivalents.
* The main issues are either not ensuring that the bottom edge of the screen is tight against the scuttle: top corners then sit proud... Or pushing the screen assembly too deep into the body with a pattern frame: the pattern frame clip profile doesn't quite match the factory rubber# and setting the screen deep prevents the rubber from clipping fully. Fitting the rubber after mounting the screen only makes this worse... The more you press the rubber to try and seat it, the deeper the screen sits and the more the rubber won't clip in. The rubber trim coming off then becomes a self fulfilled prophecy. It is essential to have two people fitting the screen in order to correctly locate the bottom of the screen and to ensure that both top corners are simultaneously seated at the correct depth.
# another reason not to use glue or sealant on the rubber.
Alnico Blue
  • Costa del 'Saffend
    • 2001 2.6 CDX estate
« Reply #33 on: 19 September 2018, 18:59:04 »
Ok thanks chaps  . . .gonna call & request all genuine parts & screen . Then follow that up with an e mail so there is something on record that i have requested this  ;) ;)
British made Celestion Alnico Blue = best sounding guitar speaker ever, sadly now made in China
Alnico Blue
« Reply #34 on: 12 October 2018, 19:59:25 »
Tomorrow is the big day  . . .got the confirmation text for the appointment from Auto Windscreens today  . . .2 hour slot from 10.45 am  . . .. fingers crossed .
Been over 6 weeks since the process was started  . . .am I feeling lucky ? ::) ::)
Let you know tomorrow   :D :D :D
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #35 on: 12 October 2018, 20:44:31 »
Hope it all goes well. :y
I now need one for the 190. Heard an almighty crack the other day as a stone hit it. huge stonechip which very quickly became a foot long crack.  ::)
Alnico Blue
« Reply #36 on: 13 October 2018, 12:53:00 »
Faith is now restored  . .. Auto Windscreens guy turned up this morning .  Screen not GM  but Pilkington . .. but all trims & rubbers were GM.
Guy seems to have done a real good job  . . he commented on the "Bad" fit of the existing screen & said it must have caused huge wind noise as it was.
The new screen looks & fits so much better .
Oh . . .yes  . . . forgot to mention  . . they called him up from WALES  :o :o  to do this job as Omegas are a "Bit tricky  to get right"  if not encountered before  ::) ::)
But definate thumbs up from me to Auto Windscreens   :y :y :y :y
And a big negative to those tos*ers at AUTOGLASS . . . give them a miss IMO  >:( >:( >:( >:(
« Last Edit: 13 October 2018, 13:00:17 by Alnico Blue »
Migv6 le Frog Fan
« Reply #37 on: 13 October 2018, 14:36:53 »
Glad your sorted at last mate.  :y
amba
  • Medway towns
    • German V6
« Reply #38 on: 13 October 2018, 14:39:37 »
Glad is now sorted Al. :y
Agree about being abit specialist as mine was fitted twice >:(..second guy was proper old school and said he had fitted lots of them when they were a popular car so knew what he was doing and made a first class job
« Reply #39 on: 13 October 2018, 14:42:49 »
Good job jobbed  :y
« Reply #40 on: 13 October 2018, 20:23:50 »
I think my insurance policy says autoglass are their 'preferred' company. So I guess I'd have to use them.
Having said that, on the two occasions they've done mine in the past, they've been fine.
Alnico Blue
« Reply #41 on: 13 October 2018, 20:34:08 »
As did my insurance Steve . . . but after being messed around by Autoglass  . . insurance co let me use their "other" company  ::) ::)
« Reply #42 on: 13 October 2018, 20:37:54 »
Right....well.....that's good. Just be more careful with this one!  ;D
Pages: 1 2 [3]  All   Go Up
