Author Topic: Sticky switches!  (Read 5680 times)
nilocp
  • Halifax, West Yorkshire
Sticky switches!
« on: 06 September 2018, 18:51:14 »
It has probably been asked before, but what can do to get the 'sticky' of all the switches without removing the white logos?
Thanks
Colin
johnnydog
  • Lancashire
    • 3.2 Elite sal & est x3!
Re: Sticky switches!
« Reply #1 on: 06 September 2018, 23:54:38 »
This topic was discussed recently.
Hope this helps.
http://www.omegaowners.com/forum/index.php?topic=143303.0
nilocp
« Reply #2 on: 07 September 2018, 16:13:54 »
Thanks johnnydog, I hear that, but unfortunately there is no solution to the problem!
Any other ideas anyone?
Colin
« Reply #3 on: 07 September 2018, 18:21:42 »
Colin
Keeping it clean is the long term solution. 14-18 years of previous owners not bothering is the hard part.
Time, effort and https://www.ebay.co.uk/p/Ambersil-Foam-Upholstery-Cleaner-500ml-7003/1426783928 is all you need. And only use cloth or a plastic scraper (best use for a credit card) ;)
And regardless of the naysayers on tother thread, the above is all I ever used on my taxi during 160k of abuse.
nilocp
« Reply #4 on: 07 September 2018, 23:43:21 »
Hi Doc, I will give it a go!!
johnnydog
  • Lancashire
« Reply #5 on: 08 September 2018, 13:57:52 »
As said in the other topic, any upholstery cleaner will clean the switches of any recent sticky residue directly as a result of sweaty, dirty or greasy fingers, but once the surface coating of the switches deteriorates and becomes excessively tacky / sticky, no amount of cleaners or solvents will remove it. It seems this is cause by age and general exposure to daylight or sun as they are coated with a soft plastic / rubbery like finish to improve their feel or texture. This wouldnt occur to plain hard plastic switches. At this point, nothing really can restore the switches; however the coating of the door handles can be removed with care which improves the appearance as there are no symbols as on the switches to worry about.
cam.in.head
  • West yorkshire
    • omega cdx 2.6 auto
« Reply #6 on: 08 September 2018, 16:22:17 »
Hi colin. I take it you are talking volvo here or have you got youself another omega ?
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #7 on: 08 September 2018, 16:45:27 »
Nail varnish remover takes off the coating on the switch
« Reply #8 on: 08 September 2018, 17:16:32 »
Colin
DG, safe to just spray it on neat, or do you spray onto a cloth and wipe switches?
nilocp
« Reply #9 on: 08 September 2018, 18:33:29 »
Cam.in.head, no not Volvo! Still getting rid of Omega bits! You OK Chris??
Colin
« Reply #10 on: 08 September 2018, 19:13:26 »
Colin
Spray it on neat :y
cam.in.head
  • West yorkshire
« Reply #11 on: 09 September 2018, 13:03:30 »
Colin
hi colin .yes fine thanks. May be contacting you later if you have a cheap bonnet or know of anyone who has a grotty one for free ! . Reason will all be revealed !  !
nilocp
« Reply #12 on: 09 September 2018, 14:33:30 »
Chris, no the bonnet has gone. Still other stuff.
Be good to see you when you are passing
Colin
« Reply #13 on: 09 September 2018, 14:43:48 »
Colin
Spray it on neat :y
Might get some and chuck on the Jag, as I hear that suffers...
« Reply #14 on: 09 September 2018, 21:29:39 »
Likewise the the volume up/down on the steering wheel of my Merc that has the same rubberised surface .... a baby wipe doesn't work  ::)
