Selecting home network hardware
Started by Viral_Jim, 07 September 2018, 22:54:52
deviator
Quote from: jimmy944 on 07 September 2018, 22:54:52
As part of the new house design, and off the back of the other network related thread, I've been thinking about network hardware and it's raised a couple of questions. Which hopefully a few members here, or indeed our esteemed leader may be able to answer.
Im planning to run in cables down to network sockets for TVs, PS4, SWMBO'S work pc and a few Sonos products. I'll also need to retain WiFi for ad hoc phone and tablet browsing.
I'll need to run in some cable to add a secondary WiFi point and network sockets in the detached garage building (part of which will surreptitiously become my office in due course). I also may want to run a cable down to a greenhouse at the end of the patch of land for a raspberry pi project in the long term. So, questions...
1. Can someone recommend an alternative to the BT/sky homebox router that will support c 10 wired connections in the main house and do WiFi and act as my ISP box.
2. Can I run network cable alongside the ringmains without causing interference/impacting performance.
3. As per 1. But a smaller unit for the garage C5 wired connections and some WiFi.
4. Is there a max run length for network cable, if so, what is it. 5. Budget, particularly re. 1& 3, the WiFi doesn't need to be enterprise grade stuff, so neither does the price tag ;).
Thanks in advance  :y
1. Don't buy another router, buy a switch.
2. Yes
3. You want a wifi access point? Just buy lower end/middle market access point. I say don't spend too much because they'll probably be another wifi standard next week.
5. 100m is the standard, but I've run up to 150m before with only slight loss of speed.
Quote from: Kevin Wood on 10 September 2018, 10:16:29
.. of course, in 5 years time we'll probably all be kicking ourselves for not wiring up our houses with fibre. ::)
I think 10Gbps cat6 will future proof us for the next 10-5yrs.  I don't think the 100Gbps cards are coming down to a sensible price soon, nor are 100Gbps linecards for routers, that are still a smidgen over $1m (list) per card.
Quote from: deviator on 10 September 2018, 12:37:15
That's a bigger problem than it looks, because you must be getting retries on TCP (it wont sync a little bit slower, it will be 1Gb, 100Mb or 10Mb). Which means udp packets are being lost.
zirk
In 20 years time we'll probably all be wondering why We bothered in the first place, as the Internet went Bang 3 years prior to that.  :D
Quote from: TheBoy on 10 September 2018, 17:37:13
Just a tad over budget for my understairs cupboard at the moment, then. ::)
