Author Topic: How fast  (Read 3327 times)
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
How fast
« on: 08 September 2018, 19:10:48 »
malcy-p's post on his "flat" engine brought up rev numbers at which the rams open.On my commute due to speed limits/weight of traffic the highest mine-3L auto-gets is a nudge over 2,000rpm[accelerating from a standstill and keeping up with other traffic]while most of the time it's circa 1,500rpm.The last time I had it to 70mph[a long long time ago for a variety of reasons]it was-from memory-running at something below 3,000revs,so how fast do you need to be going for these things to operate?
Re: How fast
« Reply #1 on: 08 September 2018, 19:12:43 »
All about engine speed ::)
So, as per the Multiram explanatory guide, 3 and 4k rpm :y
BazaJT
Re: How fast
« Reply #2 on: 08 September 2018, 19:23:35 »
Sorry DG I should perhaps have been clearer it wasn't engine speed I was meaning it was road speed although I do realise that this would be dependant on what gear the car was in at the time,but surely the auto should have hit third at least-if not top-by the time you're at those revs?
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
Re: How fast
« Reply #3 on: 08 September 2018, 20:09:56 »
Depends on throttle position. On full throttle  in an auto, I guess 2nd is engaged at 6000 rpm, 3rd and 4th similarly. That's how to get maximun acceleration.
Re: How fast
« Reply #4 on: 08 September 2018, 20:44:10 »
Exactly, road speed is utterly irrelevant  :D
  • Auckland
    • Mazda MPV
Re: How fast
« Reply #5 on: 08 September 2018, 22:16:30 »
Press the sport button and bury the accelerator pedal in the carpet and it will come close to the red-line in each of the lower gears before changing up. :)
« Last Edit: 08 September 2018, 22:19:52 by Andy H »
BazaJT
Re: How fast
« Reply #6 on: 09 September 2018, 09:03:10 »
Ah,all that would explain a lot then as I've never used the sport button in either the Senators nor the Omega and-from memory-I've never had the Omega above 4,000revs,basically because I've never had the need to.
Re: How fast
« Reply #7 on: 09 September 2018, 14:04:26 »
You should try it some time. It's therapeutic. :y
Re: How fast
« Reply #8 on: 09 September 2018, 14:42:49 »
The opening depends on rpm and load.
My Omegas usually sit up towards the redline most of the time...
New POD
  • Miseryside
    • NEED MV6
Re: How fast
« Reply #9 on: 15 September 2018, 18:09:09 »
I use the sport button at least once every day.  :y
