Author Topic: Short nose vs long  (Read 2898 times)
annihilator
  • Wirral
    • Omega Tourer V6
Short nose vs long
« on: 12 September 2018, 17:42:35 »
I've noticed my '95 elite 3.0 has a short nose plenum and I think the later ones have long nose versions. Apart from the obvious what's the difference.
Re: Short nose vs long
« Reply #1 on: 12 September 2018, 17:48:53 »
Better breathing, recall 2.6 would have been better with short. But due to DBW it has to go long.
Fuse19 will explain better   :)
« Reply #2 on: 12 September 2018, 18:18:23 »
I believe that it's covered in the Multiram guide in faqs ;)
If considering a swap, you'll need the longer throttle cable and possibly some of the egr/sai gubbins...
annihilator
  • Wirral
    • Omega Tourer V6
« Reply #3 on: 12 September 2018, 21:40:48 »
Found this on the old site
http://oldsite.omegaowners.com/forum/YaBB.pl?num=1156774455/all
Too little difference to bother about.
annihilator
  • Wirral
    • Omega Tourer V6
« Reply #5 on: 13 September 2018, 07:35:54 »
Thanks
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #6 on: 13 September 2018, 19:08:15 »
A tad more torque on the Long Nose at low RPM, assuming the Multi Rams are working correctly.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #7 on: 13 September 2018, 19:11:14 »
I stuck a long nose on a 2.5 once because I thought it would be a good idea  ;
After all the fannying around, it felt slower  ::)
