Author Topic: Windscreen washer sensor  (Read 4626 times)
atann
  • Canterbury
    • Vauxhall Omega 2.6 CDX
« on: 19 September 2018, 21:42:21 »
Pulled out the sensor on the back of the washer tank, too drain all the old screen wash out. Refilled to max, now getting low washer fluid warning on dash?
Re: Windscreen washer sensor
« Reply #1 on: 19 September 2018, 21:56:00 »
Refitted correct way up? although almost impossible to get wrong...
Plug refitted fully?
Not much else to go wrong with it ;y
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #2 on: 19 September 2018, 22:13:46 »
You need to replace the complete tank. cost is about £36 I believe.
« Reply #3 on: 19 September 2018, 22:25:35 »
Eh ???
WTF are y'all smoking?
    • 530D M Sport, 330i Coupe
« Reply #4 on: 19 September 2018, 23:07:17 »
Your thinking of the coolant expansion tank.  :y
atann
  • Canterbury
« Reply #5 on: 19 September 2018, 23:30:22 »
That was my initial first thought. Shall I pull it out & try it the other way up? I’ll have too be quick though😀
« Reply #6 on: 19 September 2018, 23:46:04 »
Can't suggest much else without seeing how it is currently fitted...
terry paget
    • 3 Astras 2 Vectra
« Reply #7 on: 20 September 2018, 08:50:06 »
Quite right. Silly me.
« Reply #8 on: 20 September 2018, 09:23:15 »
I can only think that that the float has come off.
If it was upside down, then the sensor would never 'see' an empty bottle, is the float was missing, then it'll never close the magnetic switch.
atann
  • Canterbury
« Reply #9 on: 19 November 2018, 23:24:06 »
Unplugged the sensor & rotated it 180 degrees. Still same issue. The tank is definitely 100% full. Any other ideas?
« Reply #10 on: 20 November 2018, 01:13:07 »
New sensor... Presuming that it is correctly plugged in...
