Big Thanks to TB and NickW
Started by amba, 22 September 2018, 18:24:55
amba
Assuming the back board is the part that is suspect,am I correct in understanding that if I remove this part from the original NCDC which worked on mute,and replace it into the new NCDC it should in theory waork as before and mute down the system for the phone to function ?
Just want to be crystal on what is involved  :y
I'm sure when I saw this before, swapping rear board cured it.  Obviously, not all faults are the same cause, so I can't guarantee it.
But no harm in trying, as long as you take your time :y
