Author Topic: Thanks yet again to Serek and SOS Automotive  (Read 6520 times)
Re: Thanks yet again to Serek and SOS Automotive
« Reply #15 on: 17 October 2018, 21:19:54 »
And if it’s loads of bits? Impossible to source now I hear.
Improvise with resin or silicone  :y
Best way to access is back onto ramps, support (not lift) the diff then undo one mount from the chassis member. If it drops it's toast. Refit and repeat on other mount.
If they're properly dead, you'll know as the mount frame falls off.
Whilst on ramps, the donuts can also be checked with a pry bar :y
« Reply #16 on: 17 October 2018, 21:27:56 »
Cheers. Bolts only should just drop out then? Trying to remember from last rear spring change I did, how they came off.
Thanks for polish link, £130 for 4 though. Plus postage.
    • 530D M Sport, 330i Coupe
« Reply #17 on: 17 October 2018, 21:28:58 »
Two bolts hold each one, like a collar design
