White Goods Thread!!
Started by Sir Tigger KC, 18 October 2018, 23:59:48
dave the builder
Here is an informative Bigclivedotcom video on fuses  :)
https://www.youtube.com/watch?v=kx35WN3uLis
Lizzie Zoom
Quote from: Sir Tigger QC on 19 October 2018, 12:44:25
Quote from: Lizzie Zoom on 19 October 2018, 11:54:43
If I was Sir Tigger's wife/partner though I would still take advantage of the situation and push for a nice, new, up to date, fridge freezer! :D :D
Typical response from a woman!  ::)
Always looking for an opportunity to go shopping!  :-X  ;D
Too true!! :D :D :y
dave the builder
Quote from: STEMO on 19 October 2018, 17:28:30
Quote from: dave the builder on 19 October 2018, 16:58:33
Fascina.....ti......zzzzzzzzzzzzzz  ;D
:D ;D
It may not be avid viewing for everyone
big clive does inject a little humor into some of his video content
John Ward's dulcet delivery  can induce coma state at times  ;D
Quote from: dave the builder on 19 October 2018, 17:42:51
:D ;D
humour  ::) ::) ::)
is there not still such a thing as a motor fuse? ie it allows a shed load of amps for the initial start up of the motor but will blow if the motor starts to pull a high current in use
dave the builder
Quote from: Andy B on 19 October 2018, 21:12:58
:D ;D
humour  ::) ::) ::)
I put that first  ,but the spell checker told me it was wrong ,so i trusted it ,being the internet and all that  :-\
dave the builder
Quote from: Andy B on 19 October 2018, 21:15:46
most big motors have start capacitors ,or starter relays etc ,HRC fuse links are outdated and used on domestic portable appliances/ stuff
fuses will take double the rating for so long before blowing ,some will happily glow away for half an hour before calling time
I could find a informative video if anyone is interested  ;D
I suspect many OOFers still have wylex rewirable fuses in t'lectric cupboard  :-X
Quote from: dave the builder on 19 October 2018, 21:31:59
It's a bugger when they blow in the dark and your wife has run out of candles.
LC0112G
Quote from: STEMO on 19 October 2018, 22:22:32
Nahh, you just stick a handy screwdriver/knife/fork between the prongs and shove it in, then worry about fixing it properly the next morning. :y
dave the builder
Quote from: LC0112G on 19 October 2018, 23:53:18
Nahh, you just stick a handy screwdriver/knife/fork between the prongs and shove it in, then worry about fixing it when the screwdriver/knife/fork blows . :y
Fixed that for you  ;)
personally ,I feel safer with my MK 21 way multi RCD ,RCBO, MCB board looking after such matters , electric is expensive, don't like the idea of it leaking all over the place  :P
Plugged our new fridge in and switched it on...
Ten minutes later, a loud pop and everything went off...
Turns out the dog had taken a liking to the plug ::)
She had damaged enough of the insulation that when she went back for a second go, she pinched the live and neutral together :o
Fortunately no harm done :)
