Author Topic: Space saver tyre  (Read 2761 times)
pauls
  • By the sea minehead
    • Bmw x3
Space saver tyre
« on: 21 October 2018, 16:55:26 »
Could somebody please advise.
I have 235/45/19 on the front and 255/40/19 on the back. I noticed that the space saver is t135/90/17. If i had a flat either on the front or back could i use this space saver without causing any damage to transfer boxs or diffs. Car is a bmw x3.
I have looked on a couple of different sites and the tyre radius is ok but iam more worried about any damaged to could cause.
Re: Space saver tyre
« Reply #1 on: 21 October 2018, 17:01:15 »
As long as the rolling radius is the same, you'll be fine  :y
Obviously it won't drive as well and check the manual/dealer to confirm that it's suitable for either end... Suspect it's rear only for stability reasons  :-\
« Reply #2 on: 21 October 2018, 17:02:53 »
if the spare's radius is the same as those on the car & is the spare originally supplied, I can't see a problem ... after all, the spare is only intended as a temporary/get you home wheel.  :y
