Author Topic: MOT question  (Read 2947 times)
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
MOT question
« on: 01 November 2018, 11:09:36 »
The Omegas M.o.T. is due this month,while it's not covered many miles since last year so I'm reasonably confident about it there is one issue it has that I'm unsure of.More often than not the speedo and rev counter don't work but everything else-fuel and temp gauges,warning lights and mileometer[including trip meter]-continues to work as they should.Question is if the speedo/rev counter don't work at the time of the test is this a fail?Tried re-seating dash to no avail,maybe spray connections with contact cleaner and see if that works?
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: MOT question
« Reply #1 on: 01 November 2018, 11:20:35 »
Fail. But it may go unnoticed
RIP Paul Lovejoy
amba
  • Medway towns
    • German V6
Re: MOT question
« Reply #2 on: 01 November 2018, 11:22:14 »
Not being negative but usual issues with Speedo and rev counter are abs pump module but worth removing clock cluster and giving contacts anc spray with switch cleaner of similar as a first point .
BazaJT
Re: MOT question
« Reply #3 on: 01 November 2018, 11:26:00 »
Thought it might be a fail-but hoped it wasn't-can't see them not noticing as they use the rev counter for emissions test don't they?ABS pump module sounds costly and if that's the case probably write the car off.
Webby the Bear
  • Northampton
Re: MOT question
« Reply #4 on: 01 November 2018, 11:34:15 »
RIP Paul Lovejoy
Re: MOT question
« Reply #5 on: 01 November 2018, 11:41:47 »
IIRC the speedo is a fail item, but quite likely they won't notice it unless they drive it. Rev counter is not required. Their emissions tester should include a probe to pick up RPM if it's required for a test, but it doesn't have to be exact in any case.
The ABS issue only affects the speedo, so it sounds more likely to be an issue with the instrument panel, IMHO. First check there is to ensure it's firmly seated in the dash, because otherwise the connections to it can become intermittent.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: MOT question
« Reply #6 on: 01 November 2018, 11:45:45 »
I seem to remember someone saying there are multi plugs at the side of the battery that can cause dash/speedo faults if not plugged in / good contact  :-\
worth a look  :)
you have been spannering there  :D
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: MOT question
« Reply #7 on: 01 November 2018, 11:46:16 »
As Kevin says very unlikely to be noticed on test especially as milage will have changed from last test
other rides
BazaJT
Re: MOT question
« Reply #8 on: 01 November 2018, 18:12:05 »
Did check the multi plugs near battery some while ago[think it was DG who suggested this]and they seemed ok to me but will check again and spray with contact cleaner.Will also remove clocks and spray contacts with contact cleaner and see how I go from there.If no joy i'll take it for test and see what the outcome of that is before spending further money on it.A little more information which may or may not help,when not working the rev counter needle still "flutters" against the stop and on a couple of occasions when they have been working when I've turned the engine off the rev counter needle has stayed indicating tick over revs until I've turned the ignition back on when it's then dropped to its stop.
Re: MOT question
« Reply #9 on: 02 November 2018, 10:05:08 »
Had the same fault on a friend's car .. we left the centre screw out that holds the clocks in and that fixed it (been like that for several years now! ;D)..
