Author Topic: Connection speeds...  (Read 5103 times)
Re: Connection speeds...
« Reply #15 on: 18 August 2008, 21:52:37 »
That's with Mrs. KW playing WOW in the background, obviously. ::)
« Reply #16 on: 18 August 2008, 21:56:05 »
On what should be a 8mb line...
Joys of the island eh :(
Though to be fair it's often nearer the 5mb speed
It will be an 8M line, its just the servers will be overloaded and hence you wont get 8m throughput.....
It will be network capacity more likely than server.  Only servers some ISPs go through are proxies, though guess you could call the HGs a server, but they have the power to handle the full capacity of the central.
JonArgraig
  • Isle of Angelsey
  • The Camera Ninja
« Reply #17 on: 18 August 2008, 21:56:27 »
Just called a lad in the office and had him run one from there...
19mb down... and back up :)
Got to love the dedicated hard lines :)
even the public (ish) WiFi is 10mb duplex....
wish I lived nearer work, the amount of people that bring lappys in to down on is scarry
« Reply #18 on: 18 August 2008, 21:56:41 »
Plus net is thier wisdom have removed thier results history.
This is actually the worst I have ever seen mine run at since I was upgraded to 6.5 Mbit :-/ :-/
Phil why are you testing to the moscow server? try it again on London or Maidenhead ;)
My best ever:
test 1 min ago :(
it should have little impact on the readings........
For example, here is my reading to Bombay (Mumbai)
The ping is obviously greater because there is one hell of a lot more routers and servers to get through......but the download speed is similar.
The only time i migh be quicker is if the test server is on the same network as your IP provider.
hotel21
  • The Kingdom of Fife
« Reply #19 on: 18 August 2008, 21:57:20 »
Mine looks alright, as far as I can see.... :-/
« Reply #20 on: 18 August 2008, 21:57:29 »
I had 7M off my BT line earlier today (using the dedicated bt login), which shows throughput of line (during day, so exchange not busy), but doesn't show internet bottlenecks.
« Reply #21 on: 18 August 2008, 21:58:16 »
« Reply #22 on: 18 August 2008, 22:00:53 »
Not bad as I live miles from the exchange too!!
« Last Edit: 18 August 2008, 22:02:00 by Lazydocker »
« Reply #23 on: 18 August 2008, 22:01:28 »
My best ever:
test 1 min ago :(
Well spotted matey.
Tested it to london and bach it was even slower.
Am putting it down to the hols at the moment with the kids being off.
Unless Plusnet have throtled me (Again) ::) ::) ::) ::) ::) ::)
carper
  • Yorkshire - Hecky
« Reply #24 on: 18 August 2008, 22:01:43 »
I often get this speed, this is from last month.........
this is now during busy times.........
« Reply #25 on: 18 August 2008, 22:03:20 »
Thats better.
Mind you it is latter at nigt. :y :y
« Last Edit: 18 August 2008, 22:16:59 by skruntie »
hotel21
« Reply #26 on: 18 August 2008, 22:03:29 »
Thanks....
Did the same as M_DTM and tried Mumbai....  It is a long way by pack camel, don't you think??
« Reply #27 on: 18 August 2008, 22:05:59 »
Next time we decomission one of our news servers, I'll have to quickly get a laptop in to do a speed test. 1G of unfettled internet goodness :)
« Reply #28 on: 18 August 2008, 22:07:03 »
2 mins later
« Reply #29 on: 18 August 2008, 22:10:05 »
Thanks....
Similar ping time but then telewest and virgin are one and the same ....
Pages: 1 [2] 3 4  All   Go Up
