Author Topic: drivers side door wont open  (Read 19264 times)
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« on: 25 November 2018, 12:00:22 »
My door will not open the locking system is working ok as is the key method of locking.I feel sure that it is a rod to the lock that has become detached .the outside handle and the inside handle do not release the lock. Any ideas before smashing the door card to access the lock etc..All help gratefully received.
Re: drivers side door wont open
« Reply #1 on: 25 November 2018, 15:29:23 »
Remove the lock from the passenger door and examine and play with it.
You'll figure out exactly what makes it open without using any of the handles.
Then fabricate a tool based on your discovery and apply it to the driver's door mechanism.
Oh, and order a replacement mechanism for the driver's door along with a new rubber for the top edge of the door as I will almost guarantee that yours is split for about two inches from the rear edge :y
I know exactly what you need to do, but cannot post it for legal reasons. Alternatively bring the car to me.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #2 on: 25 November 2018, 16:46:12 »
Thanks Doctor for the reply where are you?
« Reply #3 on: 25 November 2018, 16:58:45 »
West Sussex, about 10 miles from Horsham :y
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #4 on: 25 November 2018, 17:14:25 »
Thanks again not too far away I am in Ashford Kent . It sounds as though you could save my door card. I will see how I get on and will ask for your help if I am not successful in solving my problem.
Ron
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #5 on: 25 November 2018, 18:27:01 »
Me again Doc do you know if a locking unit for a 2.2 2002 drivers side is the same as the 2003 2.6?
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #6 on: 25 November 2018, 18:33:14 »
I fitted an entire door from a 2.2 sport to my 2.6 v6 53 plate CDXi ,all good  :y
« Reply #7 on: 25 November 2018, 18:40:44 »
Identical across the range :y
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #8 on: 25 November 2018, 19:01:09 »
Thanks  Doc I am preparing for all eventualities   Rear door and passenger side locks are plentiful but not drivers door side. :y
  • Online Online
« Reply #9 on: 25 November 2018, 20:45:22 »
aren't both front door locks the same? Like wise both rears the same?  :-\
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #10 on: 25 November 2018, 20:59:04 »
They're handed.
  • Online Online
« Reply #11 on: 25 November 2018, 21:02:52 »
They're handed.
There's something in the door that's the same for both front doors ....  ;D ;D
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #12 on: 25 November 2018, 21:04:18 »
Only success I have had in this situation is window down, sacrifice door card and massively douse the mechanism in WD and work the mechanism manually with a long screwdriver, said lock is still working years later
  • Chatham, Kent
« Reply #13 on: 25 November 2018, 21:15:32 »
The plastic sheet that's supposed to keep moisture away from the door card?  ;)
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #14 on: 25 November 2018, 21:28:16 »
Thanks omegod I am trying to save doorcard.You say window down why is that.Did you manage to find a replacement door card.I have found 3 on line but guess which one is missing.
Pages: [1] 2 3 4  All   Go Up
