Author Topic: drivers side door wont open  (Read 19202 times)
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: drivers side door wont open
« Reply #30 on: 28 November 2018, 08:59:35 »
Hello Doc thanks for all the help
Ron :y
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #31 on: 28 November 2018, 15:40:18 »
Doc PM sent
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #32 on: 28 November 2018, 15:46:19 »
Two weeks ago my daughter, living in London, had the same problem on her 03 ex-plod Omega. The RAC got in somehow, and advised her not to lock it again. She'll be home for Christmas, and will require me to sort it out. I imagine a change of driver's door lock unit will rectify it - is that correct?
There is clearly a trade trick known to the RAC and DG. We wonder what it is. I heard tell of a policeman, summoned to the aid of a fair lady with a locked car, said 'Look away ma'am', then dealt the car an almighty blow and the door popped open. Where he administered the blow she did not see.
« Reply #33 on: 28 November 2018, 15:53:27 »
Sounds like that could be either the door lock mechanism or the central locking motor.
« Reply #34 on: 28 November 2018, 16:13:15 »
« Reply #35 on: 28 November 2018, 16:17:06 »
Door not opening with the exterior handle when unlocked either manually or by remote can only be the mechanism itself. CL motor(solenoid) can be moved by hand with minimal effort, so unless it's been filled with araldite, won't be the problem ;)
terry paget
    • 3 Astras 2 Vectra
« Reply #36 on: 28 November 2018, 16:43:47 »
This is an 03 car, only Omega I hve ever owned that cannot easily be opened with the key.. I know one should be able to open it turning the key with force, but I never managed it, and I tried. I will report back when the car is here.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #37 on: 28 November 2018, 18:05:31 »
Omegod PM sent
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #38 on: 30 November 2018, 19:40:39 »
Jon pm sent
Ron
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #39 on: 30 November 2018, 19:56:52 »
Replied  :y
terry paget
    • 3 Astras 2 Vectra
« Reply #40 on: 04 December 2018, 19:37:12 »
Is the fault now rectified? If so, may we know how it was done, without revealing any secrets?
« Reply #41 on: 04 December 2018, 19:41:38 »
Not yet. No.
In that order.
terry paget
    • 3 Astras 2 Vectra
« Reply #42 on: 07 December 2018, 10:11:06 »
The car is still in daily use, so presumably can be opened normally using the inside and outside handles. I suppose it could still be the deadlocking mechanism or the central locking motor that prevents reopening.
« Reply #43 on: 07 December 2018, 11:02:40 »
You presume wrong.
Door is latched closed, and as I understand it, the lock works as it should. The latch release has jammed. Apparently the locksmith who replaced the ignition barrel was unable to open the door. All that said, I haven't seen the car, but clear instruction was given as to what needs to be done in order to open it, so not clear as to why it isn't :-\
terry paget
    • 3 Astras 2 Vectra
« Reply #44 on: 07 December 2018, 13:36:22 »
You presume wrong.
I think we are talking about different cars, Doc. I presumed Kevin's post referred to my post 7 minutes earlier, could be wrong. I presume my daughter is still driving around in her insecure Omega, could be wrong.
I imagine Robson drove his car around with driver's door locked, gaining access via front passenger's door, until finally stopped by the ignition barrel seizure.
Pages: 1 2 [3] 4  All   Go Up
Page created in 0.465 seconds with 20 queries.
