Author Topic: atp  (Read 20237 times)
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: atp
« Reply #15 on: 27 November 2018, 13:13:29 »
It's a good job TB has no time* to read these posts about him having problems with deliveries . or you'd all be for the cull list  :-X
*Now he's driving a corsa at or bellow speed limits ,his commute time is considerably extended   ;D
Re: atp
« Reply #16 on: 27 November 2018, 17:11:33 »
What was tb’s problem?
The quality is shiter than shite.  Think of the nastiest set of Omega wishbones you've come across, then sink a bit lower.  The TREs (if you buy the kit) are equally awful.  I certainly wouldn't allow them on my car. I'd rather have some non descript Chinese monkey metal.
That's, of course, if they ever turn up.  And they are impossible to deal with when the shite doesn't turn up.
Re: atp
« Reply #17 on: 27 November 2018, 17:18:02 »
but if you buy through Ebay, they seem to be a bit more reliable wrt delivery times :y
Nope, they are every bit as crap when buying through egay.  And they wait the maximum amount of time on egay's resolution system before replying, with a stall reply, so you have to keep going round in circles, waiting 8 days each time.
Last time I went through this particular nightmare, they couldn't give me a tracking number, yet on the last day before you can get egay in intervene claimed DHL had lost it.  Strangely, having got one of my DHL contacts to check it, DHL never picked anything up from ATP (or anywhere else that couldn't be accounted for) destined for me.
So, I know that they are liars that sell substandard junk.
Re: atp
« Reply #18 on: 27 November 2018, 17:20:03 »
At the time ECP was supplying Lemforder parts, which were miles better in build quality.  :y
So I bought all I needed from them in the end.
Although I don`t think TB is a lemforder fanboy & might dispute the above statement
Lemforder, whilst not the same quality on these items as they once were, are a good enough replacement.  I have seen ECP try to shift cheap wishbones as Lemforder in the past, but that seems to have improved a bit since they were taken over a few years back.
Re: atp
« Reply #19 on: 27 November 2018, 17:20:57 »
Don't diss the might Corsa, complete with bright red inserts in the dash.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: atp
« Reply #20 on: 27 November 2018, 17:59:23 »
one will definitely be the low oil pressure warning light  :y
the other is probably the battery light /alternator failing  :-\
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: atp
« Reply #21 on: 27 November 2018, 20:30:30 »
Have they significantly gone down in standard then?
Last time WBs lasted 5 years. TREs lasted 6 years and drop links still on from years ago!!!
RIP Paul Lovejoy
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
Re: atp
« Reply #22 on: 27 November 2018, 21:39:20 »
Conflicting views, Webby! As I said earlier, I am happy with my ATP wishbone kit, which Serek fitted for me a year ago and still fine. Perhaps you could ask Serek what he thought of the quality of the kit?
Ron.
Re: atp
« Reply #23 on: 27 November 2018, 22:08:33 »
Do they fit? Check.
Do they work? Check.
Are they cheap? Check.
For less than £100 for wishbones/droplinks/track rods, what more do you want/need ::)
Rods2
  • Sandhurst Berkshire
    • 1999 3.0 Elite Estate
Re: atp
« Reply #24 on: 27 November 2018, 22:26:51 »
Do they fit? Check.
Do they come with a free baseball cap as TB needs one to go with his Corsa. :P
Webby the Bear
  • Northampton
Re: atp
« Reply #25 on: 27 November 2018, 22:56:41 »
Do they fit? Check.
And probably an oil pressure switch  🤐
RIP Paul Lovejoy
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: atp
« Reply #26 on: 28 November 2018, 11:27:40 »
Do they fit? Check.
Nowt wrong with a baseball cap , I wear one most of the time, and have a baseball bat ,just saving up for a baseball now  :)
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
Re: atp
« Reply #27 on: 28 November 2018, 17:36:44 »
Do they fit? Check.
Protection? ;)
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: atp
« Reply #28 on: 28 November 2018, 17:46:23 »
Do they fit? Check.
Protection? ;)
Yes, the baseball CAP protects my head from getting cold and keeps the sun out my eyes  :y
the baseball bat protects my car from thieving scum bags  ;)
anti theft device clicky
obviously, when i have more money, i will buy a ball too  ;D
if you have a wooden baseball bat, make sure you have a baseball too, or it could be considered an offensive weapon apparently  :P
Re: atp
« Reply #29 on: 28 November 2018, 18:11:05 »
Do they fit? Check.
The single most expensive part is the geometry adjustments after.  So if they only last the warranty period (if you're lucky), it still makes it the expensive option.
As with many things, the cheapest often works out far from the cheapest.
