Author Topic: Climate control panel, no power.  (Read 4027 times)
Duke01
  • Southampton
    • 03 3.2 Elite Lpg
« on: 27 November 2018, 22:43:11 »
Evening.
This morning the climate control worked, this evening it doesnt.
No power, no lights.
Fuses seem ok, any clues?
Re: Climate control panel, no power.
« Reply #1 on: 28 November 2018, 00:28:57 »
Anything else not working?
Dimmer switch not set to minimum?  ::)
Duke01
  • Southampton
    • 03 3.2 Elite Lpg
« Reply #2 on: 28 November 2018, 07:04:36 »
Everything else is fine.
johnnydog
  • Lancashire
    • 3.2 Elite sal & est x3!
« Reply #3 on: 29 November 2018, 00:14:35 »
Is the blower working? I would check fuse 17 under the steering wheel (I think it's 17). Even if it looks ok, I'd swap with another of the same rating and try it.
Duke01
  • Southampton
    • 03 3.2 Elite Lpg
« Reply #4 on: 29 November 2018, 21:18:26 »
No the blower isnt working.
The whole climate system is dead.
Ive read that its fuse 14, and also read fuse 33, the massive one.
Both swapped and still dead.
I am at a loss.
« Reply #5 on: 29 November 2018, 21:24:10 »
Have you checked the under bonnet fuses?
Whilst you're at it, check the scuttle for water... ;)
Duke01
  • Southampton
    • 03 3.2 Elite Lpg
« Reply #6 on: 29 November 2018, 21:30:12 »
Ahh, good point. Will do, thanks.
Duke01
  • Southampton
    • 03 3.2 Elite Lpg
« Reply #7 on: 07 December 2018, 20:08:59 »
After much checking of relays, and replacing fuses with known working fuses, i bit the bullet and got the climate control panel, from ebay.
It works!
Hot air once again.
I recommend Omegas52 on ebay, item was very well packed and as described. I had a gearbox from him in the past and that was fine.
atann
  • Canterbury
    • Vauxhall Omega 2.6 CDX
« Reply #8 on: 07 December 2018, 23:26:42 »
It works!
Hot air once again.
I’ve had a few bits of him as well. Always approachable if there were any issues.
amba
  • Medway towns
    • German V6
« Reply #9 on: 08 December 2018, 13:32:41 »
Yes Nigel comes well recommended ...good guy :y
Page created in 0.024 seconds with 20 queries.
