Author Topic: ignition barrel will not turn  (Read 4911 times)
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« on: 04 December 2018, 12:09:51 »
Ordered a new barrel yesterday as mine was sticky today key wont turn.What do I do now. Drill out the barrel if so how deep? I now have a jammed drivers lock and a jammed ignition barrel. Any body want an Omega
deviator
  • Chesterfield
Re: ignition barrel will not turn
« Reply #1 on: 04 December 2018, 12:38:14 »
Take the key, turn it 90 degrees to the normal insertion way, whack the grey biscuit part of the barrel a few times. If that doesn't free it off, try again. If that doesn't work try turning the key whilst pulling in one or the other direction on the steering wheel.
« Reply #2 on: 04 December 2018, 16:04:13 »
Also see pm ;)
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #3 on: 04 December 2018, 16:14:34 »
Try putting some graphite (pencil lead will do) on the key. It sometimes helps.
« Reply #4 on: 04 December 2018, 16:17:53 »
If the key is in position one, remove the shroud, and insert a 4 mm Allen key into the hole underneath the barrel. It should pop out.
If you remove any keyring attached to the key, the shroud should be able to be persuaded over the key for access  :y
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #5 on: 04 December 2018, 17:27:08 »
Squirt any old lube down the keyhole, remove the fob from your key, put the chip somewhere safe, put key in and get some light  tension on it with pliers/grips then tap the middle of the key with a light hammer, such as a tack hammer and the key should turn to aid barrel removal
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #6 on: 06 December 2018, 15:03:19 »
The barrel was jammed solid. Hernebay locks came out today after me calling them yesterday.They got the old barrel out and fitted  the one I purchased at GM. Great job.Now onto getting the drivers door to open.
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #7 on: 07 December 2018, 16:14:02 »
If the ignition barrel is getting stiff, it's worthwhile removing it while you still can, stripping it and cleaning it. One more job that does not need doing in a car's first 10 years, but needs it in the next.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #8 on: 07 December 2018, 16:38:35 »
I was so surprised That I started the car with no problem took it into the garage 5 yards away  switched off whilst I got my tools to remove barrel  tried to start the car again and the key would not turn.
terry paget
    • 3 Astras 2 Vectra
« Reply #9 on: 07 December 2018, 19:14:12 »
What rotten luck. I had a Senator getting stiff, then one day it would not turn at all so I could not turn to position 1 to remove it. No locksmith would touch it, so I put drills down the middle of the lock until it suddenly fell to bits and I could turn it with a screwdriver. Now when a lock stiffens I take the cylinder out, take in indoors, strip it and clean it. There is a forum guide, it's a fun job.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #10 on: 07 December 2018, 19:38:04 »
before the locksmith came a certain recovery man tried to turn the key without success and damaged the insert. The locksmith said this is the first that he had seen snapped off.
