Pages: 1 2 3 4 5 6 [7] 8 9   Go Down
Author Topic: Astra oil pressure warning light coming on  (Read 37118 times)
Re: Astra oil pressure warning light coming on
« Reply #90 on: 23 January 2019, 11:38:14 »
So ,if you know which relays do the back rad fan , bypass one at a time and see if your fan spins up  :y ,assume you have now tried the fan directly connected to a battery or power probe  :-\ refitted fan  :P
video here clicky for cars with air con but your's won't be all that different ,just no front fan and 2 relays not 3
I just pop the lids off so I can:
1) Observe if the contacts are making when activated
2) You can then manually press the relay contacts together to see the fan (or other ancillary) operate
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #91 on: 23 January 2019, 14:38:05 »
Tantalising suggestion - but how do I pop the lids off?
« Reply #92 on: 23 January 2019, 16:08:37 »
Have a good look at a spare relay ;)
terry paget
    • 3 Astras 2 Vectra
« Reply #93 on: 23 January 2019, 16:08:47 »
Swapped relays K12 and K13 (Hella made in USA) for K12 and 13 from 04 car (made in Spain). Idled engine for 30 minutes, fan never turned; disappointing. Plugged in diagnostic, revved engine to raise coolant temperature, at 102 degrees the fan engaged. Phew!
So it looks like it was a failed relay.
« Reply #94 on: 23 January 2019, 16:10:26 »
Now sort the top end rattle before it eventually kills another car ;)
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #95 on: 23 January 2019, 16:16:15 »
I would just pull the relays ,test them on the bench, then check you have 12v + at the   live terminal of the relay socket,then jump the switched and live terminals and see if fan spins up  :y
(because you can do that test without the engine being hot and the ecu calling for the fans to be on)
removing the covers may be possible on newer relays , but you run the risk of the covers popping off every time you want to pull the relay  ;D
also have you pulled the fuses and checked they are sound with a continuity tester / multi meter ,or are you just looking ,thinking they are ok  :-\
ok, getting somewhere now ;D
terry paget
    • 3 Astras 2 Vectra
« Reply #96 on: 23 January 2019, 19:25:07 »
I checked the fuse for continuity, it was OK.
I found popping the relay cover tricky. I have removed one, cracking it in the process. As you say, this could make removing this relay again challenging.
If the fan fails again, I could pop this relay in and press the points closed, then the fan should turn. Or, as you suggest, I could simply remove a relay and put power on the output terminal with a simple link from 12v+ to output terminal, i.e. terminals 85 to 87.
I presume the relay that failed was the low temperature low speed one, if so goodness knows at what temperature the high temp full speed one kicks in.
terry paget
    • 3 Astras 2 Vectra
« Reply #97 on: 23 January 2019, 19:26:40 »
Next job, Doc, but I shall wait until sister returns my Omega.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #98 on: 23 January 2019, 20:17:51 »
Probably says that on the sensor....
I wouldn't bother with dismantling relays, but keep a couple of spares. You've broken a number of cars Terry, emptying one of the relay boxes would have been a good idea.
« Reply #99 on: 23 January 2019, 22:20:50 »
Why wait? Removing those gauze filters takes ten minutes including a making a cup of tea ???
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
« Reply #100 on: 24 January 2019, 00:13:51 »
Agree with getting rid of the filters, but it was probably noisy due to the excessive heat.
Laying a rubber road.
« Reply #101 on: 24 January 2019, 08:59:09 »
Blocked gauzes won't help any.  ;)
terry paget
    • 3 Astras 2 Vectra
« Reply #102 on: 24 January 2019, 17:02:10 »
Hi Doc,
just checking - are these shells the gauzes to remove?
« Reply #103 on: 24 January 2019, 17:07:15 »
Them's the ones  :y
terry paget
    • 3 Astras 2 Vectra
« Reply #104 on: 24 January 2019, 17:13:57 »
Is it missing an O ring? There is one O ring, just behind the third groove, but no bigger O ring in the groove by the bolt bracket.
Pages: 1 2 3 4 5 6 [7] 8 9   Go Up
