Electric wing mirrors
Started by pauls, 16 January 2019, 19:49:27
henryd
As Uncle Stemo says,either the switch or the door harness making and breaking with door movement,try them again with the door open and see if owt changes
other rides
Some vehicles, DAF to name one, kills the power to the radio and door switches whenever the door is open or reverse is selected...
All that to say, just be mindful that the door switches may not work with the driver's door open ;)
pauls
I have ordered a new switch so will let you know Monday when it turns up :y
pauls
Replaced the new switch today and nothing :(
I surpose its time to strip the door and check the wiring.
pauls
I forgot to ask. Does the cable cover thing from the door to the car just pull off.
Usually but you will need to unplug the loom in order to remove it to improve access to the actual wiring ;)
