Author Topic: Crank sensor  (Read 5767 times)
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Crank sensor
« on: 19 January 2019, 11:45:58 »
Think crank sensor on way out.
Have in stock 90492006, is it suitable for my 3.2.??? Confussed of hoof'land. :)
Hoof'land storeman.
Enceladus
  • London
Re: Crank sensor
« Reply #1 on: 19 January 2019, 12:50:17 »
I believe that part number is for earlier V6 with a rectangular connector. Yours should be either 90492061 (Siemens) or more likely 90540743 (Bosch). These have oval sides on the connector so they won't fit the rectangular type. The Siemens and the Bosch are not interchangeable even though they will both fit. The only way to reliably tell whether yours is Siemens or Bosch is to look at the numbers on the sensor head.
I don't think that the sensor with the rectangular side is fully compatible with the oval versions.
« Last Edit: 19 January 2019, 12:52:58 by Enceladus »
Re: Crank sensor
« Reply #2 on: 19 January 2019, 12:50:27 »
Don't think so :-\ early 2.5 one iirc...
biggriffin
Re: Crank sensor
« Reply #3 on: 19 January 2019, 12:53:01 »
Going to  physically check...
Hoof'land storeman.
Enceladus
  • London
Re: Crank sensor
« Reply #4 on: 19 January 2019, 12:56:55 »
See if you can post up a pic of the numbers on the sensor, to aid positive ID.
biggriffin
Re: Crank sensor
« Reply #5 on: 19 January 2019, 12:59:23 »
Don't need to, it's early square type plug.  Brand new in the bag with gm label on. So best do a for sale advert later.
Hoof'land storeman.
Enceladus
  • London
Re: Crank sensor
« Reply #6 on: 19 January 2019, 13:12:44 »
I meant a pic of the one that's on the car at the moment. It could be a Siemens or a Bosch. More likely to be a Bosch. The GM part number might or might not be on the sensor head, but it will always have a Bosch logo and Bosch numbers of some description. At least if it's a factory original as opposed to aftermarket.
Re: Crank sensor
« Reply #7 on: 19 January 2019, 13:16:29 »
Later ones definitely Bosch. Rounded plug iirc as per Debs guide  ;)
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Crank sensor
« Reply #8 on: 19 January 2019, 13:19:20 »
You could have done that first....... :-*
Re: Crank sensor
« Reply #9 on: 19 January 2019, 13:31:50 »
And where's the fun in that? :D
biggriffin
Re: Crank sensor
« Reply #10 on: 19 January 2019, 13:58:59 »
So I've had a crank sensor, that's no bloody good for the barge, so now need to find a new one,, anybody want to do a swap for the one I've got, for the correct one  :o
Hoof'land storeman.
biggriffin
Re: Crank sensor
« Reply #11 on: 19 January 2019, 18:09:52 »
Wanted advert now posted. :y
And a for sale advert.
Hoof'land storeman.
Enceladus
  • London
Re: Crank sensor
« Reply #12 on: 19 January 2019, 19:28:38 »
The GM 90540743 sensor, that you likely need, either from GM/Opel or Bosch should be a Bosch 0 261 210 131. If these prove pricey then maybe consider a Valeo aftermarket which apparently comes with a 5 year warranty @ £23.72 delivered. Please see here. Valeo product is all over European made cars.
Re: Crank sensor
« Reply #13 on: 19 January 2019, 21:07:04 »
The Omega is a fussy sod when it comes to sensors... Go genuine ;)
Vega
  • The Netherlands
    • Omega Saloon 3.2
Re: Crank sensor
« Reply #14 on: 21 January 2019, 21:52:07 »
