Author Topic: auto diming mirrior conector  (Read 8139 times)
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
Re: auto diming mirrior conector
« Reply #15 on: 28 January 2019, 19:37:31 »
My CD spec had the connecter tucked up just as DG says.  :y
nellys coupe
  • buckinghamshire
    • hyundai coupe
« Reply #16 on: 31 January 2019, 13:02:53 »
i ve checked mine again and ive not got the connector :(
coupe rebuild master
« Reply #17 on: 31 January 2019, 17:54:29 »
So follow the guide ;)
nellys coupe
  • buckinghamshire
    • hyundai coupe
« Reply #18 on: 02 February 2019, 12:36:06 »
i will do but iam waiting to get a haynes manual so i can wire up the 4th wire :y
« Reply #19 on: 03 February 2019, 11:49:52 »
From memory...
Red +12v fused permanent. Behind cabin fuse box. Use handbook/Haynes to identify correct fuse.
Black +12v fused ignition. Behind cabin fuse box. Use handbook/Haynes to identify correct fuse.
Brown 0v passenger footwell.
GreyYellow dash switch illumination. Connect to sunroof supply.
BlueRed Speed signal. Connect to sunroof supply.
Rest is memory related  ;)
nellys coupe
  • buckinghamshire
    • hyundai coupe
« Reply #20 on: 03 February 2019, 15:37:37 »
nellys coupe
  • buckinghamshire
    • hyundai coupe
« Reply #21 on: 03 February 2019, 17:03:58 »
it seams that the later auto diming mirriors are wired up diffrent to early one the one ive got is from a corsa d and is wired diffrent to and omega mirrior. :(
« Reply #22 on: 03 February 2019, 17:43:43 »
Told you that when you first suggested it ::)
Quote from: nellys coupe on 22 January 2019, 18:17:40
Quote from: Doctor Gollum on 22 January 2019, 17:29:14
Auto dimming mirror is basically plug and play :y
Especially if you buy one that has the correct plug... Change over is around '51 :y
thanks mate mine is a 2000 model so anything before then should be ok
Vectra C one won't fit... Plug is completely different. You need a non rain sensor Omega one.
However...
You say yours is a 2000 car... Is the front grill on the bonnet and are the window switches on the front doors?
If yes, then you'll probably find the plug tucked up behind the interior light... If it's an earlier non facelift car, you might be less fortunate  :-\
Still not convinced that you haven't found the plug...
« Last Edit: 03 February 2019, 17:47:08 by Doctor Gollum »
« Reply #23 on: 03 February 2019, 18:12:42 »
The 12v, courtesy light 12v, 0v are all available at the courtesy light.  The reverse signal is white/black in passenger kick panel.
« Reply #24 on: 03 February 2019, 18:20:41 »
Forgot about that one ;)
I only mentioned the fuse box in case it was wanted to wire it in 'factory'  :)
nellys coupe
  • buckinghamshire
    • hyundai coupe
« Reply #25 on: 03 February 2019, 18:51:43 »
However...
trust me it is not there my friend ;)
nellys coupe
  • buckinghamshire
    • hyundai coupe
« Reply #26 on: 09 February 2019, 18:53:53 »
its finally done. ;)
