Author Topic: Corsa C new key/chip?  (Read 3155 times)
Diamond Black Geezer
    • & a silly coupe coming...
« on: 27 January 2019, 23:12:01 »
Hello chaps
My sister has gone and got herself a first car, Corsa C 1.0 12v. Seems a decent one, very low mileage, few niggles, but good for a 15 year old car.
Key started to get a little troublesome, the spare works perfectly. So... whats involved in getting a new key coded? I'd assume it's the same basic setup as a MFL/FL Omega. The physical key works fine, buttons etc, it's just the chip which clearly isn't talking to the immobiliser 100% reliably all the time.
So whats her options of getting a new key coded, anyone fancy the job / recommend anyone?
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: Corsa C new key/chip?
« Reply #1 on: 28 January 2019, 12:13:03 »
Try the key the other way up if it does not read the chip ,if that works mark the key for future reference  :y
some key fobs block the ID40 chip signal in one way .
as you have 2 ID40 chips ,one in each key ,just a new case may tidy things up  :-\
if the spare key is not a door remote and the main key is ,you could swap ID40 chips .
a completely new key wold need cutting and programming to the ecu if you don't/can't transfer the guts (car pass required i'd have thought)
« Reply #2 on: 28 January 2019, 13:12:52 »
First step is to remove any other car keys from the keyring :y
« Reply #3 on: 28 January 2019, 13:14:51 »
This info has been passed on, ta chaps.  :) I'm try and get some feedback if these tips work...
« Reply #4 on: 28 January 2019, 13:54:38 »
Tech 2 can do the work and basic diag via the live data, needs the car pass for security code
« Reply #5 on: 29 January 2019, 00:15:47 »
Who's furthest north on here with Tech 2 services? as the car's in Cleethorpes, North East Lincolnshire.
Suppose taking a day trip to travel to someone would be an option (would be her first long-distance drive) too.
« Reply #6 on: 29 January 2019, 07:38:46 »
Me, Nottingham  :y
« Reply #7 on: 29 January 2019, 20:59:16 »
Me, Nottingham  :y
Well, technically, Highlander is further North.  But too far North for Lincolnshire :D
« Reply #8 on: 29 January 2019, 20:59:33 »
Grand!
I'll pass the message on. By the way, depending what's actually required (I'm still presuming a new chip only, paired to the car) what prices are we talking - happy if you'd rather send info via pm.
Thanks, Mr DTM  :y
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #9 on: 30 January 2019, 09:51:50 »
Check simple stuff first, such as the connections from the battery to the circuit board. I have an Omega key which is currently giving problems due to the connection between the two.
Hopefully a dab of solder will fix it.
« Reply #10 on: 31 January 2019, 15:27:31 »
More good points! I'll pass that on too. Her feller is well into his computatering, so fairly handy/familiar with squinting at PCBs and the like.
« Reply #11 on: 31 January 2019, 17:46:21 »
Corsa C has a different battery setup which is not soldered to the PCB so should be ok  :(
