Author Topic: Eco mode not worky  (Read 4559 times)
grifter
  • Paisley, Scotland
    • Omega 2.6 CD / Elite 3.2
Eco mode not worky
« on: 29 January 2019, 13:32:08 »
As per title, the light doesn't come on display when I press eco mode button, what should I check?
Re: Eco mode not worky
« Reply #1 on: 29 January 2019, 14:19:16 »
Does the aircon work?
ie is the compressor engaged with the light off?
grifter
  • Paisley, Scotland
« Reply #2 on: 08 February 2019, 06:12:52 »
The compressor would usually always kick in, although I was having issue getting cold air out it, the pressure was ok last time I checked. I did have to top it up a few times last year, seemed to hold a charge for a while after that. In saying that the eco-mode button always worked.
« Reply #3 on: 08 February 2019, 10:27:35 »
That doesn't answer the question...
Would and usually are quite subjective...
It either works or it doesn't  ;)
« Reply #4 on: 08 February 2019, 12:52:02 »
Whether the air con works or not doesn't affect the operation of the ECO light IME.
I think the issue is probably in the climate panel - defective button or light.
« Reply #5 on: 08 February 2019, 13:28:35 »
Presumably a Tech 2 session would narrow it down...  :-\
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #6 on: 14 February 2019, 10:45:38 »
Eco, just switches compressor off, so need to see if compressor is working,
Engine running is the compressor going round, Eco switch press, see if compressor stops or starts, also compressor won't run if not sufficient gas.
Hoof'land storeman.
« Reply #7 on: 14 February 2019, 11:03:33 »
True, but even not working, the button should still work as expected.  ;)
    • 530D M Sport, 330i Coupe
« Reply #8 on: 14 February 2019, 12:38:17 »
Also don't believe it will run if ambient air temp is less than 4 degrees - to stop the system freezing.
