Author Topic: Ccrt700 sound issue  (Read 3349 times)
annihilator
  • Wirral
    • Omega Tourer V6
Ccrt700 sound issue
« on: 29 January 2019, 16:54:19 »
Just recently my radio has started to behave as if I've turned the volume right down each time it switches off.
The auto logic is on so comes on/off with the ignition.
When I first start the car it's barely audible so I turn it up to a decent level and it's OK until I park up and then get back in and the volume has reverted to very quiet.
Not sure what's going on.
Cheers John.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Ccrt700 sound issue
« Reply #1 on: 08 February 2019, 13:36:27 »
Assuming you have the Code, Pull it out and unplug it for 24 Hours the then back in again (Make sure its physically switched Off with Ing On and again Ing. Off before discounted the rear Connectors), worth a try as they do get confused sometimes.
Other than that could be an Issue with the Speed Sensor input.
« Reply #2 on: 08 February 2019, 14:37:44 »
Which might be an early warning of an abs ecu fault... :-\
annihilator
  • Wirral
    • Omega Tourer V6
« Reply #3 on: 18 February 2019, 14:02:25 »
Reset as suggested and now works as it should. :y
Cheers John.
zirk
  • Epping Forest
« Reply #4 on: 18 February 2019, 21:02:00 »
Glad to hear its sorted.  :y
well,   ....I cant actually hear it from here but you know what I mean.  ;D
