Author Topic: obtained decent climate control panel/need to fit  (Read 3605 times)
Toledodude1973
  • IPSWICH U.K.
  • 2002 2.6 elite,1973 ,Gas van,1974 victor fe
    • 2.6 OMEGA ELITE 2002
« on: 04 February 2019, 19:28:51 »
I managed to obtain a new climate control panel for my F/L saloon, i need to remove old one from console ,will i need to remove radio block or is there a way of removing without doing that?
Help would be appreciated thanks  Paul
2002 omega slowly morphing into 2003 omega with increasing doner parts fitted
Re: obtained decent climate control panel/need to fit
« Reply #1 on: 04 February 2019, 19:47:18 »
Ashtray out. Radio out. Surround out. Climate out from back of surround. In that order ;)
Toledodude1973
  • IPSWICH U.K.
« Reply #2 on: 04 February 2019, 19:57:13 »
Thanks DG is there a guide for ashtray removal ,surround etc ,are there hidden screws etc thanks again
Alnico Blue
  • Costa del 'Saffend
    • 2001 2.6 CDX estate
« Reply #3 on: 04 February 2019, 20:01:48 »
[/highlight]
The good Doctor  makes it sound so easy  . . . I've done one  . . .it's not difficult more fiddly.
If your head unit comes out easily that is most of the battle over . Careful with the ashtray they break easily as I recall  :P :P
Thinking there must be a guide of some sort on here  . . .otherwise I probably would not have tackled it  ::) ::)
British made Celestion Alnico Blue = best sounding guitar speaker ever, sadly now made in China
« Reply #4 on: 04 February 2019, 20:15:39 »
Three screws and the radio is the sum total of (un) doing :D
Toledodude1973
  • IPSWICH U.K.
« Reply #5 on: 04 February 2019, 20:22:46 »
Thanks DG and my omega saviour i will attempt this tomorrow and will post back  :y
Toledodude1973
  • IPSWICH U.K.
« Reply #6 on: 05 February 2019, 17:33:56 »
Fitted replacement control ,thanks for help DG and Al   Hardest bit was removing radio block ...wouldn't shift at first and you risk damaging it but finally came out with some wriggling! New climate block just clipped in and works fine
Thanks again OOF for fixing Ommy again Paul
Alnico Blue
« Reply #7 on: 05 February 2019, 18:28:24 »
Splendid . . .job done  :y :y
