Author Topic: Focus ,03 pwr steering pipe disconnection  (Read 2133 times)
Alnico Blue
  • Costa del 'Saffend
    • 2001 2.6 CDX estate
« on: 10 February 2019, 11:33:33 »
hi all
         planning a job on Swmbos 03 Focus . . . replacing the power steering pump as its now very noisy. I'm going down used replacement with pulley still attached route , so no need to remove old pulley.
After trawling through the Focus / Ford forums/ You tube etc.I cannot find a "how to " on this.
It looks fairly simple   . . remove aux belt  . . .4 bolts hold the pump on .  BUT . . . is there a special tool to remove the 2 fluid pipes to the pump ?
The bottom one looks like it will just undo with a crows foot spanner but the top one looks like it may require something special to get it off .
Has anyone removed these 2 pipes in the past  & could you advise me of how it is done .
Have a "Haynes" on order  . . but not holding out too much hope on that giving a clear instruction on how this is done  ::) ::)
TIA   Al   :P
« Last Edit: 10 February 2019, 11:35:05 by Alnico Blue »
British made Celestion Alnico Blue = best sounding guitar speaker ever, sadly now made in China
Alnico Blue
Re: Focus ,03 pwr steering pipe disconnection
« Reply #1 on: 10 February 2019, 11:57:43 »
hi all
TIA   Al   :P
Update:   seems there are several versions of this pump on several different engines  ::) ::)
A c second investigation of mine seems to show that both connections may just be ordinary hose clips  :-\ :-\ ??? ??? ???    Crows foot only needed for later/alternate versions it seems . Best I wait until replacement pump arrives along the "haynes" book of bull.
Pretty sure replacement pump on order is correct one though  ;)
Alnico Blue
« Reply #2 on: 16 February 2019, 13:08:15 »
All sorted this morning  . .  Replaced knackered pump ,no issues with pipe connections , HP was a union threaded into the bottom of the pump, LP was just a hose clip   :y
Bit messy getting old fluid out , but other than that easy peasy  ;) ;)
Much easier access with the OS headlight removed  (takes 5 mins)
Noisy rumble has gone totally  . .all good   :y :y :y
Brownie points scored with SWMBO ;D ;D ;D ;D
  *Haynes book was about as useful as a chocolate teapot  ::) ::)
« Last Edit: 16 February 2019, 13:11:26 by Alnico Blue »
