Author Topic: LSD problem.  (Read 9537 times)
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
LSD problem.
« on: 12 February 2019, 18:10:58 »
Trying to figure out what the problem is with the 3.2 auto, this is only pulling away on left or right angles i.e roundabouts and junctions....the problem being that as I start to pull away, I get a fairly loud clicking and vibration from the rear end,IIRC this may have been dealt with a fair while ago,but a search didn't reveal anything..mileage is currently 102k. TIA :y
Re: LSD problem.
« Reply #1 on: 12 February 2019, 20:35:23 »
Diff issue?
Oil level OK? CV joints OK?
Vega
  • The Netherlands
    • Omega Saloon 3.2
Re: LSD problem.
« Reply #2 on: 12 February 2019, 20:49:21 »
If it feels like a bad shock absorber on one side, then your LSD is worn out.
While driving it will engage en disengage and that feels like a bad shock.
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
Re: LSD problem.
« Reply #3 on: 12 February 2019, 20:58:57 »
The shocks are virtually brand new Bilstein B4's fitted nine months ago,so Im thinking it's got to be one or even both of the possibilities that Dr G has outlined.  ::)
Vega
  • The Netherlands
    • Omega Saloon 3.2
Re: LSD problem.
« Reply #4 on: 12 February 2019, 23:18:32 »
I am not saying that your shocks are bad, but it feels like it, but only if you have a LSD
If you have a normal diff, oil, bearings, to much play.
And then you get this
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
Re: LSD problem.
« Reply #5 on: 13 February 2019, 08:33:51 »
Once the car is under power,everything is normal except for the initial start off, diff is quiet...no whine or rumble. Will have to get the whole thing checked out. ::)
Re: LSD problem.
« Reply #6 on: 13 February 2019, 09:18:58 »
Might be worth changing the diff oil, adding the correct LSD additive, before doing anything more drastic.
jb
  • bucks
    • 3.2 Elite
Re: LSD problem.
« Reply #7 on: 14 February 2019, 20:56:04 »
Known issue once diff oil well used....yours could be 15yrs plus old..easy fix, drain old oil and replenish with correct oil and the little tube of gm friction modifier
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
Re: LSD problem.
« Reply #8 on: 14 February 2019, 21:47:18 »
Advice taken.....going up to Serek's place next Friday, CV joints check and diff oil change.....fingers crossed that will cure the problem :y
Re: LSD problem.
« Reply #9 on: 14 February 2019, 22:07:09 »
Might also be a dicky gearbox mount...
Easy enough to check and change if required  :y
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
Re: LSD problem.
« Reply #10 on: 14 February 2019, 22:10:49 »
Cheers Al,I'll stick it on the list :y
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: LSD problem.
« Reply #11 on: 15 February 2019, 02:07:30 »
In my experience of LSD's on the Omega, and I had a few now, is that they do thump, or a slight knock when pulling left or right out of  a junction, does they noise get louder or quieter with the TC off.
Re: LSD problem.
« Reply #12 on: 15 February 2019, 11:31:26 »
Yep. Worth checking the centre propshaft support while you're under there too.
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
Re: LSD problem.
« Reply #13 on: 15 February 2019, 22:23:39 »
Will pass that on to Serek, I haven't driven the car with the traction control on....will give it a look tomorrow :y
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
Re: LSD problem.
« Reply #14 on: 19 February 2019, 21:23:41 »
Mine was doing this last year. Changed the oil (with correct LSD oil, of course), no more problems. Not a bad job to do.
Page created in 0.024 seconds with 20 queries.
