Pages: [1] 2 3  All   Go Down
Author Topic: hard to start  (Read 12258 times)
nellys coupe
  • buckinghamshire
    • hyundai coupe
hard to start
« on: 13 February 2019, 13:11:47 »
hi guys a strange fault has arisen, when i turn the key she fires but dies again, i have to give her some gas for her to stay running, but it wont idle at fast idle just normal. i can hear the secondary air pump running. anyone got any ideas please.
              thanks all.
coupe rebuild master
Re: hard to start
« Reply #1 on: 13 February 2019, 13:14:51 »
How much fuel in it?
If more than a 1/4, then almost certainly crank sensor  :y
Pedal/Paper clip it and report back :y
nellys coupe
  • buckinghamshire
    • hyundai coupe
Re: hard to start
« Reply #2 on: 13 February 2019, 13:36:29 »
its just below 1/4 of a tank how do you paper clip it. :y
Re: hard to start
« Reply #3 on: 13 February 2019, 13:50:00 »
Put more fuel in it and retry... 2 gallons should do it  ;)
Code reading as per guides ;)
2.5/3.0 paper clip, 2.6/3.2 pedal trick :y
nellys coupe
  • buckinghamshire
    • hyundai coupe
Re: hard to start
« Reply #4 on: 13 February 2019, 13:57:40 »
ive added fuel in it as when i got it it was just above the red it was ok then. i notiched this last week so put some fuel in it but still the same problem. i have got a new fuel filter to fit. will report back over the weekend.
ive got a snap on code reader this should be ok ? :y
« Last Edit: 13 February 2019, 13:59:40 by nellys coupe »
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
Re: hard to start
« Reply #5 on: 13 February 2019, 14:19:33 »
My wife had this problem years ago on her ex-police 3.2. A change of battery cured the fault, I could not explain why.
Re: hard to start
« Reply #6 on: 13 February 2019, 14:20:28 »
Unless it's perfectly level below a 1/4, once it doesn't start, it won't without a few gallons in it... You might get lucky by levelling it.
Estates suffer more from this and can take a 4 gallon top up before starting.
Fuel filter, whilst a service item, won't solve the problem.
Enceladus
  • London
Re: hard to start
« Reply #7 on: 13 February 2019, 14:24:08 »
I wouldn't change anything until you've read the codes. Whilst the fuel filter might have crud blocking it's probably the least likely cause of your problems. Get the codes first and then decide what to do.
Snap-on is professional stuff so I would hope that your Snap-on reader would at least read and reset any engine fault codes. Might need a software update?
Re: hard to start
« Reply #8 on: 13 February 2019, 17:43:45 »
Saloons don't really suffer this, even with weak pumps. It seems unique to the Estates.
Re: hard to start
« Reply #9 on: 13 February 2019, 17:44:43 »
Just paperclip it. Forget the snapoff shite for now :y
nellys coupe
  • buckinghamshire
    • hyundai coupe
Re: hard to start
« Reply #10 on: 14 February 2019, 13:37:52 »
hi folks thank you for the help treid to read the codes this morning but i some how left the boot adjare >:( and the battery was nearly dead so its on charge know. ive treplaced the battery that was on it for one from my audi deisel which spinns it over very easy, so iam going to leave it on over knight and try in the morning. :y
atann
  • Canterbury
    • Vauxhall Omega 2.6 CDX
Re: hard to start
« Reply #11 on: 15 February 2019, 23:27:32 »
What is the pedal trick?
Re: hard to start
« Reply #12 on: 16 February 2019, 00:18:36 »
It's in the guides ;)
nellys coupe
  • buckinghamshire
    • hyundai coupe
Re: hard to start
« Reply #13 on: 16 February 2019, 20:27:12 »
hi folks i plugged the code reader in on friday nd with the engine ont running i get code 31 no rpm sighal.with the engine running i got this data.
hall sensor off
engine speed pulse yes,
knock signal load no.
mixture 1 lean.
mixture 2 rich..
not sure what to make of it weather it is a crank sensor or something else. :y
Paddy Flannery
  • Hertford, Hertfordshire
    • 2003 2.6 V6
Re: hard to start
« Reply #14 on: 16 February 2019, 21:38:14 »
hall sensor off
mixture 1 lean.
mixture 2 rich..
I don't know much but I believe code 31 is normal when engine isn't running.
Someone with more knowledge will be along soon.
Pages: [1] 2 3  All   Go Up
