Author Topic: fuel filler flap removal.  (Read 3514 times)
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
« on: 14 February 2019, 16:22:50 »
I need to remove the above item to use it for a paint match, as the car was resprayed a few years back but in a whiter shade than its original 10L. I have asked the guy who did the respray,but he can't find it in his records...just need to get some rattle cans made up for some minor fettling. TIA :y
Re: fuel filler flap removal.
« Reply #1 on: 14 February 2019, 16:42:01 »
Just a couple of torx screws iirc :y
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
« Reply #2 on: 14 February 2019, 17:33:27 »
Thanks Al, these are the two screws that are visible as you open it? then do you just have jiggle it around a bit to get the hinge free? :-\
Keith ABS
  • Maldon Essex
« Reply #3 on: 14 February 2019, 17:35:59 »
 If it is like a Monza/Carlton/Senator flap, it is recessed into the body so needs to be pulled toward the filler neck.
May need the cap off for a bit more room mate
« Reply #4 on: 14 February 2019, 18:35:47 »
Yes plus Keith's reply. The hinge is in the black plastic part and kind of swings out around the wing
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #5 on: 14 February 2019, 19:18:04 »
It must be easy, i did mine in a few seconds. :D
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
« Reply #6 on: 14 February 2019, 21:51:37 »
Thanks to all,I had to ask....I tend to break things rather than fix them. :-[ :y
