Author Topic: Drivers lock saga  (Read 9738 times)
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Drivers lock saga
« on: 14 February 2019, 16:57:55 »
I am having problems with the drivers lock in that when I unlock with the remote the button stays down all others are ok.I lift the button manually and then it will operate perfectly several times with no problem.I leave the car some time and once again the button stays down. I have tried to lubricate via the latch, one bolt removed but no better.Any ideas.
Lizzie Zoom
  • South
    • Omega 3.2 V6 ELITE 2003
Re: Drivers lock saga
« Reply #1 on: 14 February 2019, 17:09:56 »
I would say your drivers door lock solenoid has failed and will need replacement Ron. ;)
amba
  • Medway towns
    • German V6
« Reply #2 on: 14 February 2019, 17:16:03 »
Yes classic solenoid failure as LZ has advised.
No amount of lubricant etc will fix..time for replacement or if nifty with soldering iron fit new micro switches.
All covered in Guides
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #3 on: 14 February 2019, 17:51:57 »
I have just recently fitted a refurbished solenoid why does it operate ok several times after I have pulled the button up manually?
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #4 on: 14 February 2019, 18:33:07 »
broken wire in the door shut loom or poor contact on the door multi-plug  :-\
(would be consistent with intermittent fault)  :y
Lizzie Zoom
  • South
« Reply #5 on: 14 February 2019, 18:35:41 »
.............and a failing solenoid.  I have had the very same in the past, and the only answer is to replace with new. ;)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #6 on: 14 February 2019, 21:48:12 »
Is this the central locking failure you had recently. which you and DG overcame by a secret trick? After which you presumably replaced the solenoid and lock assembly.
Try removing the plastic cap on the driver's door locking lever. It may work then. If it does you will have located he fault.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #7 on: 15 February 2019, 07:04:27 »
Yes Terry that's the one and a refurbished motor fitted. Do you mean the black cover on the lever that attaches to the motor? I just cant understand why it works ok for a while and then stops working until I lift the button and then works again but not for long.
terry paget
    • 3 Astras 2 Vectra
« Reply #8 on: 15 February 2019, 09:11:46 »
I mean the plastic piece attached to the locking rod with a plastic insert. On the Omega here it is grey, trim colour. I have found in the past it can be stiff enough in the slide to resist being pushed fully up, but if missing the rod will come up. The locking insert may be the problem.
« Reply #9 on: 15 February 2019, 10:31:33 »
The inset is there for a reason... Namely to secure the rod. If it's sticking then remove, clean, lubricate and refit.  ;)
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #10 on: 15 February 2019, 15:32:48 »
I may be stupid but are your speaking about the knob that protrudes at the top of the door card with a red insert indicating door locked or unlocked.There is plenty of space for movement here.
terry paget
    • 3 Astras 2 Vectra
« Reply #11 on: 15 February 2019, 16:09:52 »
Yup.
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #12 on: 15 February 2019, 18:20:05 »
Although i agree that this sounds like a classic door solenoid faliure....The solenoid Being fitted by ron is one which had a new microswitch fitted by me, done as per kevin woods guide and ive done a few of these now for members on here and had nil fail till now.
The only thing i can think is if you cannot find any other fault..IE  door loom...Then get the one you removed from the car and get it posted to me.
« Reply #13 on: 15 February 2019, 19:29:12 »
Did you replace BOTH switches :-\
Steve B
  • Leicestershire
« Reply #14 on: 15 February 2019, 20:45:13 »
No Al i never...Just the one,That is what ive always done,even on my own cars and never had a problem,Ive even stripped the old switches down and seen that in time they burn like a set of old contact breakers/Points over time,But his fault does sound like a solenoid problem.....
