Author Topic: Wheels  (Read 3886 times)
gbh
  • forest of dean
    • omega cdx 2.6
Wheels
« on: 20 February 2019, 16:07:56 »
Just paid a visit to my local scrap yard and I saw an Sri with a set of very nice 17" rims and thought would they fit my Omega as my Elite rims are a bit rough but the tyres are good ? The tyres on the Sri are 215/50ZR17 and my Eilte are 235/45r17 the Sri tyres have some tread so use those up first I thought and then put my tyres on after is this possible ? Thanks in advance!!!!!
Re: Wheels
« Reply #1 on: 20 February 2019, 16:14:21 »
An Sri what? ::)
Wheels might bolt on, but offset is almost certainly wrong and will probably rub once the correct, Omega sized, tyres are fitted.
gbh
  • forest of dean
    • omega cdx 2.6
Re: Wheels
« Reply #2 on: 20 February 2019, 16:27:02 »
It was a Vectra I believe did take photo of wheel but how to add here?
Re: Wheels
« Reply #3 on: 20 February 2019, 16:28:40 »
B or C? B definitely won't fit... C see my previous post.
gbh
  • forest of dean
    • omega cdx 2.6
Re: Wheels
« Reply #4 on: 20 February 2019, 16:35:39 »
If I didn't swap tyres would that be ok?
Re: Wheels
« Reply #5 on: 20 February 2019, 16:43:36 »
No. It will handle differently and the speedo will be well off...
Not to mention that using tyres which aren't type approved will invalidate your insurance.
All assuming they don't rub...
gbh
  • forest of dean
    • omega cdx 2.6
Re: Wheels
« Reply #6 on: 20 February 2019, 16:48:03 »
Thanks for that invaluable info,only asking as I'd seen them fitted as I thought on a photo but happy to stick with originals and maybe upgrade to the newer rims one day  https://www.facebook.com/photo.php?fbid=10216508242691418&set=gm.10157395901841015&type=3&eid=ARDyTNOyjXAZytyMMyS8SU3-ADOeVAks-tZ1Ss4-BmLUZdBwfKfj_lQczw5lRO4wItlnvrL_sWAcNuqw&ifg=1
« Last Edit: 20 February 2019, 16:49:53 by gbh »
New POD
  • Miseryside
    • NEED MV6
Re: Wheels
« Reply #7 on: 25 February 2019, 22:12:44 »
what offset are they and what offset does a standard omega have ?  RWD and FWD vauxhalls used to have significant offset differences, which would make the handling weird.
Re: Wheels
« Reply #8 on: 25 February 2019, 22:41:33 »
Omega offset depends on wheel width... Numbers below are off memory, but confident that they are accurate :y
iirc, 16" are 6.5J ET38 225/55/16
17" are 7.5J ET35 235/45/17
18" are 8J ET30 235/40/18 (fronts) and 9J ET30 245/35/18 (rears)(Sportstars)/8.5J ET33 245/40/18(Stila)
All the Astra/Vectra stuff is ET4*.
There will be people who have successfully fitted XYZ wheels on an Omega, but what works on one car won't likely work following suspension work or with different geometry/parts. Oh, and using spacers is a dangerous bodge.
Basically, either fit the correct wheels or aftermarket with the correct offset for the rim width.
