Author Topic: Monroe Air Shock conversion  (Read 2996 times)
iansoutham
  • SE London
    • Omega 2.0 m/f/l est CDX
« on: 10 March 2019, 19:31:11 »
Hey guys, just wondering what your thoughts are on the Monroe Air Shock lots with the separate Schraeder valve for estate cars that run normal shock absorbers?
johnnydog
  • Lancashire
    • 3.2 Elite sal & est x3!
Re: Monroe Air Shock conversion
« Reply #1 on: 10 March 2019, 20:09:09 »
What reason do you want them for? Towing?
I used to have a very similar set up as the standard fitment on a 2.0 CDi Cavalier many years ago ( mid 90's?).
They were very good, but the only downside was that if you needed to tow, you had to visit an airline or have a portable tyre compressor/ pump with you which obviously delayed the journey. Equally, the suspension had to be deflated to its correct level after towing otherwise the car looked like a dragster!. There was no pressure gauge on the Cavalier, but I believe the Monroe set up does.
I presume you are thinking about it for towing, otherwise I would just go for shorter but firmer rear springs (to keep the ride height the same as original).
A built in self levelling system with its own compressor is obviously the best system, but is going be very costly to install and is likely to be cost prohibitive.
polilara
  • Finland
    • 2.6 Y26SE Elegance 2001
