Author Topic: power steering oil reservoir  (Read 3645 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
« on: 21 March 2019, 09:55:39 »
do all omegas have the same power steering fluid reservoirs
Re: power steering oil reservoir
« Reply #1 on: 21 March 2019, 11:19:37 »
I believe so.
Standard ZF part iirc :y
raywilb
    • Citroen C4 Cactus
« Reply #2 on: 21 March 2019, 20:29:47 »
7
the reason that i asked is i lose fluid & i thought i fixed the problem. initially blamed the banjo bolt as it looked wet. put new washers on it but still i lost fluid. i topped the reservoir up but the cap was really tight & all the top half of the reservoir turned . where i park at home i have to reverse with hard left hand down & i am leaving a trail of fluid that are about 2 feet apart & three inches in circumference. i rang Steve at vauxhallspareparts & he has heard of reservoirs perishing ( i hadn,t ) unfortunately he hasn,t got one. may see if a bit of gorilla glue & sealant fixes it.  :y
« Reply #3 on: 21 March 2019, 21:25:34 »
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #4 on: 22 March 2019, 06:59:47 »
Yep, all the same and also used an many makes & models of car. Shouldn't be difficult to source one.  :y
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #5 on: 22 March 2019, 15:15:11 »
Common fault, with omega is the pipe weeps, due to not using dex3, never had a leaking reservoir, .
Also check the cooler pipes at the front slight corrosion, will weep there.
Hoof'land storeman.
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #6 on: 23 March 2019, 10:02:03 »
Omegas52 on e-bay has one listed with pipe for just shy of £9.50p with postage[£5odd for the part]he's near Nottingham.
« Reply #7 on: 23 March 2019, 11:05:16 »
You can buy a BRAND NEW ONE for that ::)
BazaJT
« Reply #8 on: 23 March 2019, 12:24:45 »
No idea how much a new one was[until I looked at the BMW one on e-bay linked to in a previous post]as I've never needed to buy one,but the aforementioned BMW one is £13odd without the pipe?
« Reply #9 on: 23 March 2019, 13:40:42 »
OK, it's 4 quid more  ::)
But it does exactly what is required and is brand new rather than really old and used...
raywilb
    • Citroen C4 Cactus
« Reply #10 on: 23 March 2019, 21:08:25 »
  i think i have had something off him before . if so i do have his phone number. have fitted a bmw one, but there is a couple of reasons why the bmw is not quite right. thought its doing the job
Page created in 0.023 seconds with 20 queries.
