Author Topic: Driver's door won't close  (Read 3686 times)
danzigfan
  • Jesenice, Slovenia
    • Omega 2.5V6, 3.0V6
« on: 28 March 2019, 16:21:25 »
As above....just bounces back. I'm on my way to work by train now, car will spend the night unlocked on a parking lot :-[
Did it happen to anyone? Do parts from MFL fit to FL because I believe I still have door mechanism from previous omega somewhere in garage :-\
Re: Driver's door won't close
« Reply #1 on: 28 March 2019, 16:24:40 »
As far as the mechanical latch and locking motor concerned, they are the same across all Omega B :y
danzigfan
« Reply #2 on: 28 March 2019, 16:29:31 »
Thanks :y I just hope I find it tommorow
annihilator
  • Wirral
    • Omega Tourer V6
« Reply #3 on: 28 March 2019, 16:43:00 »
The black plastic doofer that catches on the pillar pin will be stuck down in the lock position.  ;D
« Reply #4 on: 28 March 2019, 17:00:29 »
Yep, might even be as simple as operating the handle to free it, failing that, give it a prod as it may have stuck (worth taking the lock mech out and giving it a good clean and oiling if so.
danzigfan
« Reply #5 on: 28 March 2019, 18:15:49 »
No, it moves freely but doesn't lock. I tried it with a screwdriver
jefflem
  • Netherlands
    • Omega Z22XE Elegance '01
« Reply #6 on: 28 March 2019, 20:06:10 »
Unfortunately a common problem with a few lots of the door locks. Had the same problem driving on the highway which is actually no fun in corners. :o Don’t waste time on fixing the locking system, get a new / second hand one.
  • Auckland
    • Mazda MPV
« Reply #7 on: 28 March 2019, 20:17:32 »
I had a sticking interior handle on a pre-facelift which stopped the door from staying closed.
Pushing the handle back allowed the door to latch.
danzigfan
« Reply #8 on: 28 March 2019, 21:01:31 »
Thanks for info guys, will check/replace tommorow after work :y
danzigfan
« Reply #9 on: 29 March 2019, 09:51:29 »
Came home and found out I only had front and rear driver's side locking mechanism...thought I had all four, but luckily I somehow had the one I needed :y All fine now with mechanism replaced, works as good as new. Thanks for help
