Author Topic: vacum tank  (Read 3482 times)
nellys coupe
  • buckinghamshire
    • hyundai coupe
vacum tank
« on: 30 March 2019, 21:00:26 »
hi folks iam wondering what the vacum tank that sits below the maf sensor does.? ;)
coupe rebuild master
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: vacum tank
« Reply #1 on: 30 March 2019, 21:08:21 »
It provides a reservoir for all the important vacuum systems. Multi-rams, assorted solenoids and the HBV.
Enceladus
  • London
Re: vacum tank
« Reply #2 on: 30 March 2019, 21:20:00 »
That vacuum reservoir is part of the multiram air intakes. Purpose of the multram is to flatten the torque curve.
There's a guide available here
nellys coupe
  • buckinghamshire
    • hyundai coupe
Re: vacum tank
« Reply #3 on: 30 March 2019, 21:27:48 »
yes just found it so looking at it i can convert my old system to the later one. which will make my thing ive got planned for the engine bay alot easyer. :y
  • Auckland
    • Mazda MPV
Re: vacum tank
« Reply #4 on: 30 March 2019, 21:41:59 »
The vacuum system also powers the heating and ventilation controls and the brake servo. The brake servo is itself a vacuum reservoir.
Oldest system has one vacuum reservoir/tank, newer system has two (one does engine, the other does heat & vent).
Pre-facelift have a vacuum operated valve for the secondary air injection (SAI), this was deleted on the later cars.
They are needed because the inlet vacuum disappears on full throttle so without the reservoirs you lose heating controls and multiram flap control. (you can dispense with the SAI plumbing with no penalty other than it will take longer for the cats to warm up)
nellys coupe
  • buckinghamshire
    • hyundai coupe
Re: vacum tank
« Reply #5 on: 31 March 2019, 19:35:14 »
iam going to keep the one that does the heater, but i want to loose the one that is mounted at the front of the engine. :y
  • Auckland
    • Mazda MPV
Re: vacum tank
« Reply #6 on: 31 March 2019, 19:51:27 »
You need some kind of vacuum reservoir to serve the multiram flaps otherwise it WILL kill the full throttle response.
It doesn't need to live on the back of the radiator fans - it would fit nicely in the space where the power sounder hides
nellys coupe
  • buckinghamshire
    • hyundai coupe
Re: vacum tank
« Reply #7 on: 31 March 2019, 21:40:10 »
iam going to plum it the same as later cars, :y
