Pages: [1] 2 3  All   Go Down
Author Topic: V828 MOT Passed!  (Read 14923 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
V828 MOT Passed!
« on: 01 April 2019, 17:10:29 »
2.5 petrol manual estate
Phew, what a relief. 10 advisories, including nearside headlight aim too low, repair immediately; also 4 rusty brake pipes, covered in grease, 2 'suspension component mounting prescribed area is corroded but not considered  excessive, rear inner (sill)'.
Now I must inspect the sills on Ben's X reg estate and decide whether I deem it worth while replacing the cat back exhaust with new and changing the rusty brake pipe. And what, pray, are the rear chassis legs, which he deemed corroded?
Lizzie Zoom
  • South
    • Omega 3.2 V6 ELITE 2003
Re: V828 MOT Passed!
« Reply #1 on: 01 April 2019, 17:16:36 »
Well done Terry! :y :y
b4ndit
« Reply #2 on: 01 April 2019, 17:44:41 »
Happy days :y :y
johnnydog
  • Lancashire
    • 3.2 Elite sal & est x3!
« Reply #3 on: 01 April 2019, 17:45:23 »
Did you not ask him to clarify before you drove away? I like to be present during my MOT's, albeit in the 'viewing area's, which at my test centre is literally adjacent to the MOT ramp, but this has two benefits in my view 1) the tester can indicate problem areas to you, and 2) you can clarify any work you have recently done (which shows good intent!) and in the case of my classic cars, correct him (politely of course!) with items such as minor play in taper roller bearings in front hubs, and the operation of items such as floor mounted dip switches etc.
You can also see how thorough (or not!) he is and make sure he doesn't jack the Omega up on the diff for example!
« Last Edit: 01 April 2019, 17:47:20 by johnnydog »
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #4 on: 01 April 2019, 18:02:23 »
Didn't the tester mark the suspect areas on the car? I've never had to do more than crawl under the car and look for the paint stick marks.
I would never grease brake pipes. Replacing them is cheap and easy and every one that's been marked as suspect has proved to be unacceptably rusted once removed. This is why we have safety inspections!
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #5 on: 01 April 2019, 18:15:26 »
congratulations Terry  :)
so did you have that adjusted and then have a re test  :-\
  • Chatham, Kent
« Reply #6 on: 01 April 2019, 18:24:41 »
A better question is why wasn't it adjusted as part of the test?
nellys coupe
  • buckinghamshire
    • hyundai coupe
« Reply #7 on: 01 April 2019, 18:26:38 »
well done mate. :y
coupe rebuild master
terry paget
    • 3 Astras 2 Vectra
« Reply #8 on: 01 April 2019, 18:52:27 »
No need, it was passed today with that as an advisory. Note it was too low, not too high. I shall change the adjuster in due course, hopefully when I have got the other 2.5 through MOT.
terry paget
    • 3 Astras 2 Vectra
« Reply #9 on: 01 April 2019, 18:55:48 »
Tester did try, but the adjuster had no effect. When I have time I must change the adjuster, but the other 2.5 takes priority, MOT failed and expiring on the 14th.
b4ndit
« Reply #10 on: 01 April 2019, 19:02:19 »
headlamp aim is no longer considered as part of the test only if it is so far out that either you can't see or you blind on coming traffic it is all about where the hot spot is in the headlamp tester cars should no longer fail for height adjustment latest info on the mot testers annual course  :y
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #11 on: 01 April 2019, 19:03:33 »
Because it is against the Vosa rules to adjust during a test
NT must fail the car,and enter the fault on the VTS device, then,  adjust the beam ,then re-test
It has been known for testers (NTs) to adjust headlamp aim during test  :-X
how else would halfords and the like ,survive without charging £20 per side plus to adjust
  • Chatham, Kent
« Reply #12 on: 01 April 2019, 19:05:24 »
They're very low geared, and take  lot of turns on the screw to have an effect. Other possibilities are broken adjusters, they've been wound out of the threads, or the plastic gears are loose on the shafts. All of which will require dismantling the lamp.
b4ndit
« Reply #13 on: 01 April 2019, 19:16:44 »
adjust at the end of the test and issue a PRS :y
« Reply #14 on: 01 April 2019, 19:50:35 »
Rear chassis rails are just like the front ones...
On the estate, the shocks bolt through them.
Pages: [1] 2 3  All   Go Up
