Author Topic: Could be quite expensive.  (Read 16604 times)
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
Re: Could be quite expensive.
« Reply #15 on: 06 April 2019, 13:52:06 »
DG, I was meaning more the A30 (not sure I know how large/tall a terracan is),  but you are right - there is more of me now than in yesteryear! :-[
Ron.
2boxerdogs
« Reply #16 on: 06 April 2019, 13:55:44 »
If you can't fit under the Terracan, you must be portly...  ;D
In fact there is a bit less of me down from 18 stone to 15
but I can't be arsed to mess around under cars anymore.😉
New POD
  • Miseryside
    • NEED MV6
« Reply #17 on: 06 April 2019, 20:59:05 »
why is clutch replacement like on a Cavalier with an F16.5 Gearbox.
I picked up a NOS Clutch for £15, off the Electronic Man in a Pub that is the Bay of E, and paid someone £20 to fit it, because it's a 20 minute job. Apparently.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #18 on: 06 April 2019, 21:30:45 »
It's not really possible to do that on a RWD gearbox.
But it would make a lot more sense on current complex FWD installations
  • Auckland
    • Mazda MPV
« Reply #19 on: 06 April 2019, 22:41:51 »
My mk2 Astra was probably the same design.
Take the nearside front wheel off and remove a plug in the gearbox end cover, Undo the clutch pressure plate bolts through an opening between the engine and gearbox. Pull the drive shaft out of the end of the gearbox and lift the clutch out.
Assembly is the reverse of disassembly......
It took me 20 minutes to get the car on axle stands and remove the front wheel but it might have been a 20 minute job with access to a car lift.
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #20 on: 07 April 2019, 07:42:07 »
£1300 is more than I've ever paid for a car let alone putting a clutch in one :o
« Reply #21 on: 08 April 2019, 13:49:46 »
You don't want to be man handling a TerribleCan box on a drive, they are very big and very heavy and worse still with the transfer box still attached.
2boxerdogs
« Reply #22 on: 08 April 2019, 17:13:05 »
I wouldn't even attempt it , main dealership job I'm afraid they've always looked after it .
2boxerdogs
« Reply #23 on: 11 April 2019, 10:37:26 »
Well dropped the Terracan off at the dealership at 08.30 this morning hopefully get it back later today.
« Reply #24 on: 11 April 2019, 14:43:57 »
£????. :) ;D
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #25 on: 11 April 2019, 14:58:17 »
2boxerdogs
« Reply #26 on: 11 April 2019, 15:22:16 »
2boxerdogs
« Reply #27 on: 11 April 2019, 17:42:52 »
Dealership phoned at 16.50 won't be ready till tomorrow , I'm out all day tomorrow so will hopefully collect it Saturday morning.😉
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #28 on: 11 April 2019, 18:18:22 »
£16.50 , that's a bit steep  :D ;D
 all joking aside , hope it's not too painful  :y
« Reply #29 on: 11 April 2019, 18:43:22 »
£????. :) ;D
£15
££££  :o :'(
No contact yet I'm guessing around £1500 ☹️
£1500.
A mere bagatelle for a man of your means. :y
Pages: 1 [2] 3 4  All   Go Up
