Pages: [1] 2 3  All   Go Down
Author Topic: Front arm rear bushes replaced with spherical bearings... Works a treat  (Read 11493 times)
3.2 manual
  • nr yeovil, somerset
  • the great thread ender! whoops
Modification to improve handling.
Tried to post a picture but can't work out how lol.
oh bugger, i thought that was a bit of wind!!!
Broken wishbones coming to a car near you  :-X
3.2 manual
I am wondering about that, with the front ones polybushed too. Shock loading will be greater but the wishbone is absolutely free to move up and down with little to no resistance. lol
« Last Edit: 06 April 2019, 14:03:41 by 3.2 manual »
  • Chatham, Kent
    • Ghastly 1.0l Focus
 A solid poly bush in this position transfers the movement to the structure of the wishbone, which is what causes it to break -just like bending a paper clip to and fro.
A spherical bearing constrains the movement to the ball and socket within the bearing, a structure that is specifcally designed to do that. There's no cushioning effect from this sort of joint though, so the extra control is at the cost of a lot more harshness, noise and durability. As the other two attachment points are still bushed, I don't think the disadvantages are worthwhile on a road car, let alone one that is supposed to be a big comfortable car.
The poly front wishbone bushes function  by rotating about the axis of the bolt, just like the original did. The difference is that the bushing material isn't bonded to the sleeve, so isn't damaged by poor fitting or wear.
The poly bushes don't wear, whereas these spherical bushes will end up wearing quickly with dirt ingress. Net result they will break up and either fall apart of seize... Either way the wishbone won't be far behind...
  • Chatham, Kent
That is the net result, but you'll be surprised how long they last even when completely exposed like on a four link. You get lots of warning too.
It is one of the disadvantages that I'm not prepared to accept on any sort of  road car.
3.2 manual
I did consider all of this, being a fitter by trade. The noise etc hasn't changed much due to the massive profile of the tyres. The sphericals are sealed maintainance free ptfe units, where in a different application under a lorry they were successfully dealing with over 3000kg of loading a piece. It has been done as an experiment and a close eye will be kept on the wishbones. I will post the results after a while of use. It is now very precise in corners so bonus for now :D
« Last Edit: 06 April 2019, 15:06:21 by 3.2 manual »
We had some early success with a couple of different poly bushings, but wishbones failed on both cars after about 8k miles.
I had checked mine the week before the arm snapped and there was no evidence of the impending failure. One minor crest on a fast A road was enough to shear the arm without warning. A different make of wishbone might have lasted longer, or not, but that was the end of the experiment as a second failure at speed might not have been so lucky.
Also, with rigid rear bushes, the front tie should be set to zero as the factory toe setting allows for give within the rear bush. You'll get a slight dead spot straight ahead but this is a normal side effect of a steering box. :y
3.2 manual
Cool thanks for the figure of failure time frame. Geometry set to 0.The reason I went for sphericals in the rear of the front arm instead of polybushes is I considered the force of flexing polybushes in that axis would be unsustainable for the wishbones as I have seen them snap in other cars before.
« Last Edit: 06 April 2019, 15:45:04 by 3.2 manual »
My wishbone didn't fail.  The poly did :D, Cant remember the mileage, wasn't many though.
I guess it finds the weakest point.
3.2 manual
Your probably right, it's currently searching for it on mine now lol ;D
They do drive well though 8)
Yup, mine was brilliant until the poly started to fail, then went drastically downhill fast.  Really tightened up the (usually lacklustre) steering response.
Those failed as the restricted rhe rotational movement to much and placed extra load on the weld joint, spherical joint would address that  :y
  • Auckland
    • Mazda MPV
If you cut an original rear bush in half you will find a bulge in the steel sleeve (that looks remarkably like a sphere) with a rubber bush cast around it.
Pages: [1] 2 3  All   Go Up
Page created in 0.024 seconds with 20 queries.
