Author Topic: Code PO172-52 Fuel Trim System Lean  (Read 2543 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« on: 14 April 2019, 18:05:58 »
2006 Astra H 1.6 petrol
EML came on today, code PO172-52 popped up on reader. Is this just a glitch, or a serious problem?
Re: Code PO172-52 Fuel Trim System Lean
« Reply #1 on: 14 April 2019, 18:08:45 »
Any air leaks?
Is the engine well serviced and running smoothly with no misfires?
If no air leaks and running ok it’s worth checking the maf readings
terry paget
    • 3 Astras 2 Vectra
« Reply #2 on: 14 April 2019, 19:41:52 »
Any air leaks?
Only bought the car on Friday. Engine is running smoothly with no misfires. Thanks for advice, will check the maf readings tomorrow.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #3 on: 14 April 2019, 19:52:22 »
It's about time you started your own Youtube channel, Terry.
Instead of I bought the cheapest whatever in the country, you could call it I bought a faulty Astra. Again. Somehow :o
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #4 on: 14 April 2019, 20:53:13 »
Any air leaks?
have a look at short & long term fuel trims ,front lambda switching , check the egr operates when revved
can't be many faulty astras left near Terry , he's going to have to start looking further afield  :P
terry paget
    • 3 Astras 2 Vectra
« Reply #5 on: 15 April 2019, 15:02:55 »
Cleared all codes last night, none have reappeared today. Pleased to read aircon pressure 120kPa, sounds good.  Otherwise:
EGR valve inactive
EGR position commanded 0
EGR position feedback 0.80 to 0.78
O2 sensor 1 rich/lean/rich/lean every 2 seconds or so
O2 sensor 2 lean
B1 short term fuel trim 0, varying between 4 and -4
I did not notice any mass air flow reading displayed.
« Reply #6 on: 15 April 2019, 17:11:32 »
B1 Long term fuel trim?
Page created in 0.031 seconds with 20 queries.
