Pages: 1 2 [3] 4 5 6   Go Down
Author Topic: Astra cam belt change; do I need a new crankshaft pulley bolt?  (Read 25789 times)
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: Astra cam belt change; do I need a new crankshaft pulley bolt?
« Reply #30 on: 19 April 2019, 18:31:29 »
Right. I have bought the wrong kit. Silly me. What is my best course now? Return it for a refund and buy elsewhere? Seems quickest. Or try to get my supplier to replace his rotten ktr with the right one. He did ask for car reg. no. and I gave it to him, it appears on his order acknowledgement.
the seller you brought off does not have the correct kit listed on ebay Terry
return for refund if possible
buy local or use MY links
gates kit kp15603xs is correct for z16xep https://www.gatesautocat.com/article/KP15603XS
has a"male" torx crankshaft you wanted
if you are cheaping out and not doing the waterpump i will find another link for you
Yes please.
It's a waste of time changing any of it if you are leaving the water pump,nearly every vauxhall belt failure I've ever seen has been water pump related
other rides
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #31 on: 19 April 2019, 18:35:13 »
Yes please.
the water pump runs off the aux belt on the z16xep same as an omega V6
henryd
  • west cornwall
« Reply #32 on: 19 April 2019, 18:38:34 »
Yes please.
Oops :-[, ok then  :y
other rides
henryd
  • west cornwall
« Reply #33 on: 19 April 2019, 18:40:59 »
Yes please.
I did a Corsa c 1.4 a couple of days ago so blinkered,that one does have pump in the T belt run :-\
other rides
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #34 on: 19 April 2019, 19:06:29 »
Yes please.
corsa c 1.4 is a timing chain z14xep  :-\
anyway a link for Terry
I'm  a cheap-skate and will admit it by clicking INA brand £62  ;D
or a gates kit
   gates K015603XS kit £78.61
or buy the complete Gates kit with waterpump
£86.75 Buy it now
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #35 on: 19 April 2019, 19:50:29 »
Gates belt kit is now £66. Did you say this kit includes th crankshaft pulley bolt?
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #36 on: 19 April 2019, 20:06:34 »
probably ,but I can't confirm for sure  :-\
 because i buy with water pump kit complete
also,
you have other astra 1,6 cars , so why not just buy the complete kit including water pump ,if you don't fit the water pump to this car, it's on the shelf for one of the others and delivery is Express Delivery (Other 24 Hour Courier) with the full kit
if you opt for just the £66 gates belt with rollers says friday Economy Delivery (Hermes Tracked)
but that is your choice  :y
terry paget
    • 3 Astras 2 Vectra
« Reply #37 on: 19 April 2019, 20:18:22 »
That's interseting
also,
That's interesting. Both the INA and the Gates say delivery Thursday or Friday, not good. I will check it out.
« Reply #38 on: 19 April 2019, 20:19:15 »
Two bank holidays this weekend  ::)
terry paget
    • 3 Astras 2 Vectra
« Reply #39 on: 19 April 2019, 20:31:29 »
Yes I know. That's why I planned this job for the weekend. Now I am at a loose end, with the Astra on axle stands and with a jack under the sump, hogging the garage. Might a local factor or Europarts sell me a kit?
« Reply #40 on: 19 April 2019, 20:36:51 »
One would certainly hope so... Being as what they purport to do ;)
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #41 on: 19 April 2019, 20:44:49 »
belt kit dayco £88 at eurocarshyte minus what ever bull**** discount they have  :y
terry paget
    • 3 Astras 2 Vectra
« Reply #42 on: 20 April 2019, 17:36:37 »
We progress. New belt and piulleys are fitted, now reassembling. I have twice failed to fit the crankshaft pulley concentric with the crankshaft. Engine runs but rattles. There is a shallowlip on the bottom pulley which sjhould locate in the ring on the crank pulley. Here is the bottom belt pulley, on the end of the crankshaft
and here is the crankshaft pulley
I wonder if the slot cut in the pulley is too narrow to accept the locating tongue. How could that be? Perhaps I have flattened it tightening the bolt earlier. Please advise.
« Reply #43 on: 20 April 2019, 17:41:27 »
Is the cambelt pulley on the correct way?
Is there a washer missing from the aux pulley hub bolt?
What rattles... The aux pulley or the engine?
« Last Edit: 20 April 2019, 17:44:39 by Doctor Gollum »
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #44 on: 20 April 2019, 18:13:17 »
if the harmonic damper (crankshaft pulley that runs the aux belt) was not in it's keyed slot when you did it up,it could well have spun ,mullered the ability for the key to locate in the damper now  :-\
(looking at the center hole on the damper looks worn  :o )
go check your spares car for harmonic damper and toothed crankshaft cog ? can't think what it's called  :-[
Pages: 1 2 [3] 4 5 6   Go Up
