Denso Tape
Started by Sir Tigger KC, 27 April 2019, 14:30:47
Quote from: biggriffin on 27 April 2019, 18:49:48
Another wurzel bodge up, have you been on ch5 yet dodgey old landlords.
Good landlords fix problems. Dodgy landlords don't.  :P
dave the builder
Quote from: Sir Tigger QC on 27 April 2019, 19:35:12
Good landlords bodge problems. Dodgy landlords don't.  :P
FTFY  :y
biggriffin
Quote from: dave the builder on 27 April 2019, 19:50:51
FTFY  :y
That's what I meant.. :)
Hoof'land storeman.
dave the builder
had you disconnected the boiler,removing heating and hot water from the equation ,denso tape may have sufficed
tip for next time  :y
or have a cowboy builder on speed-dial  ;D
My old house had copper pipes buried in the concrete floor when it was built in 1970.
In 2017 they leaked, 47 years later.
Will you still own the house in 47 years? Of course not, you're on OOF, you probably won't be alive in 47 years  :P :P Bury them and forget about it. :y ;)
Quote from: aaronjb on 29 April 2019, 08:41:17
Some poor bastid will remember tales from Gramps about a site where no questions went unanswered and will be jumping up and down when this thread pops up in a search ::)
 ;D But that's their problem ;)
Unless Sir Tig has some children he's leaving the place to.. in which case, maybe do the job 'properly' ;D
Quote from: aaronjb on 29 April 2019, 12:35:07
Denso tape should be just fine then :D
Quote from: Doctor Gollum on 29 April 2019, 12:41:13
Duct Denso tape should be just fine then :D
If only to hold the tiles down :P
Use Kuterlux plastic coated copper pipe if you have no buried joints, if not wrap it in a couple of layers of PVC tape (cheap and available in decent widths).
I would then add insulation over the top as this will help the heat loss to the slab a bit, even a thin layer will bee better than nothing (assuming there is enough room).
Brain fart  ;D
