Author Topic: Todays Task  (Read 2543 times)
Todays Task
« on: 21 August 2008, 21:24:49 »
Fix the bloody shower!
Awoken in the night by the sound of fast dripping water.  Soon located it to it dripping out of the shower valve.  Had to turn off the water - cold was easy, couldn't work out how to do the hot.  But turning off cold stopped the leak.
Having remembered by mum had a similar problem with her Aqualisa shower a few years ago, and spookily enough discussing it at work a couple of weeks ago, I suspected it was the cartridge.  No idea what type mine took, though, so had to strip it down and check.  As suspected, it was the cheapie manual type.
So, woke up this morning to her asking me what I'd done to the shower ::).
Had to go to Birmingham for work today, so had her ringing around plumbers merchants trying to locate the cartrudge in stock somewhere, and I swung by and picked one up on my way home.
Sorted out isolating the hot water, then changed the cartidge.  All went OK, though removing seal at back of shower body was a bit tedious, and resealing the wall plate was never going to be my strong point (and will have a 2nd go tomorrow - might have wiped away a shade too much), but its cured the leak :)
Pizza on order, I'm starving!
Re: Todays Task
« Reply #1 on: 21 August 2008, 21:25:48 »
Mmmmmmm pizza...
Well done Jaime :y
Re: Todays Task
« Reply #2 on: 21 August 2008, 21:34:59 »
Jaime - you any good with gutters?
Re: Todays Task
« Reply #3 on: 21 August 2008, 21:35:17 »
Mmmmmmm pizza...
Well done Jaime :y
Its just turned up :D
Re: Todays Task
« Reply #4 on: 21 August 2008, 21:35:48 »
Not really, but had to replace a couple of sections on mine...
Debs.
Re: Todays Task
« Reply #5 on: 21 August 2008, 21:48:09 »
 :y Well done Jaime; a more prompt repair than Maria`s bath overflow, especially as it seems that James has to test Archimedes` principle every time he`s there! ;D
 [smiley=2vrolijk_08.gif]
HolyCount
Re: Todays Task
« Reply #6 on: 21 August 2008, 21:50:26 »
Bet it wasn't "Eureka" he shouted as water cascaded everywhere !!!!!
Re: Todays Task
« Reply #7 on: 21 August 2008, 22:40:11 »
Good job  :y
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Todays Task
« Reply #8 on: 21 August 2008, 22:46:59 »
Get your fix all out Jaime
[size=24]"SAMMY!"[/size]
Re: Todays Task
« Reply #9 on: 22 August 2008, 08:09:02 »
Sammy is still nowhere to be seen  :'(
Martin_1962
Re: Todays Task
« Reply #10 on: 22 August 2008, 09:53:12 »
Had to do a quick repair on holiday with a sledge hammer - reversed into a block at Durgan while turning around and bent my stabilser bracket. My uncle sledged it flat
Re: Todays Task
« Reply #11 on: 22 August 2008, 16:36:28 »
Saying that, not enough room in my shower for a real decent swing!
Re: Todays Task
« Reply #12 on: 22 August 2008, 16:42:42 »
Normaly the hot shut off is achieved by the use of a gate valve on the cold water feed to the immersion heater given the age of house you have (and assuming its not a naff rather combi!)
Re: Todays Task
« Reply #13 on: 22 August 2008, 16:50:52 »
Yup, you were right, and that was what I was looking for.  Builders fitted one shelf in airing cupboard, and all the stopcocks are below this, except the one I was looking for, which was covered in blankets and all sorts of other crap she rams in there, so it wasn't until I was more awake that I found it :y
Oh, and no stupid combis here :D
Re: Todays Task
« Reply #14 on: 22 August 2008, 16:55:14 »
Also found out why the immersion heater has never worked (got a Potterton boiler here, so always good to ensure immersion works!).  As well as the controlling switch in the kitchen, there is another switch on the airing cupboard - also fitted out off site above the shelf, and right by missing stopcock.
I should add, as the hot water tank is mounted 18" off the floor (not sure why? Better head?), that shelf is quite high, and not easy to see above it too well.
