Will Omega wheels fit on a Vectra?
Started by terry paget, 22 May 2019, 22:34:57
biggriffin
Quote from: Phil on 24 May 2019, 08:01:38
Quote from: dave the builder on 23 May 2019, 21:08:37
real cars with all 3 pedals (as GOD intended) repel such demonic possession  ;D
Because DMF's, release bearings, slave, cylinders, master cylinders, bearings in the box and the clutch NEVER fail and NEVER cost thousands to replace?
Wonder if anyone with an M32 gearbox will agree it doesn't needs a head-spinning cross inserting green puke removing priest?
And back to the original question, not with Omega tyres, Vectra 17s were 215 or 225 width as OEM, the Omega tyres will make it handle worse than it does  :D
My posh vectra has 235/45/17.
Sorry for being different.
Hoof'land storeman.
henryd
Quote from: biggriffin on 24 May 2019, 09:39:36
Mine too,yours an Aero too BG ?
other rides
dave the builder
It all depends on what wheels and tyres Terry actually has  :-\
ET is usually stamped or cast on the wheel
tyre size is usually on the black rubber part
;D :D
biggriffin
Quote from: henryd on 24 May 2019, 10:13:16
   9-3 2.0t vector anniversary estate.
Hoof'land storeman.
henryd
Quote from: biggriffin on 24 May 2019, 10:47:07
A mere 2.0 ::) ;D
other rides
Viral_Jim
A 2.0lpt will be pretty sedate. Is it auto BG?
Quote from: jimmy944 on 24 May 2019, 13:15:42
More than enough for BG at his age!  ;D
He's used to driving everywhere at a constant 64-66mph in his truck, or at 30mph in his omega (bits fall off if you go much faster), so it will seem like a rocket ship.  :y
Quote from: STEMO on 24 May 2019, 13:27:41
He's used to driving everywhere at a constant 54-56mph in his truck, or at 30mph in his omega (bits fall off if you go much faster), so it will seem like a rocket ship.  :y
FTFY Uncle STEMO.  :)
biggriffin
The posh Vectra, is only A 2.0t but allegedly puts out sufficient donkeys, yes it does only have 2pedals as all vehicles should, and it's finished in a nice shade of GM's finest rare silver.  It will also comfortably attain the speed limit. :)
Hoof'land storeman.
Quote from: Sir Tigger QC on 24 May 2019, 13:47:08
Not round here.  ;D
But, yes, I stand corrected.  :y
Migv6 le Frog Fan
The 64 - 66mph trucks are the Irish ones cruising down the M6 in no particular hurry.  ;)
biggriffin
Use to, then it was knobbled,  :'(
Hoof'land storeman.
terry paget
Quote from: dave the builder on 24 May 2019, 10:26:16
;D :D
I never thought of loooking for data on the wheels. Cast on the back of the wheels on the spokes I find K835E INTRA 70645 S363E17, and around the wheels bolt holes DB KE TM XP.
I have in the past used old Senator wheels on Omegas without problem, and used the steel spares similarly, though I did find some Carlton wheels too small to fit over the brake calipers. Assuming they are all 5 bolt wheels, my concern was bolt hole location and central hole size. Basically, will they bolt on a Vectra or not?
