Pages: 1 2 [3] 4 5 6 7 8   Go Down
Author Topic: Fitting a Y32SE to a 1972 scimitar GTE.  (Read 60643 times)
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Fitting a Y32SE to a 1972 scimitar GTE.
« Reply #30 on: 15 July 2019, 22:00:35 »
Here's one in an MGB:
Fookin ell.........that should have some pull. :y
Far quicker than an MGC or MGB V8, I imagine. :y
60hp more than an MGC(and a lot lighter), about 80hp more than a stock V8 MGB and 20hp more than a stock 3.9 EFI Rover.
It's gone in without cutting the car, so it's completely legal and the 4cylinder diff ratio doesn't need changing unlike a Rover swap. Worst bit of the job is the exhaust manifolds.
It ought to go well and make a nice cruiser.
MikeyBikey
  • Cornwall
    • Reliant Scimitar GTE
« Reply #31 on: 16 September 2019, 20:04:11 »
So she's in and running.  At lot of phaffing with the fuel map as she's soo rich.
So did a fair bit of research and investigated the fueeling... NOT.
Had an idea on the way home. Just took 4 values off every cell in the fuel map and went for a drive.
Still overfuelling horribly at the lower rev range & under load but once she shakes the misfire off she just launches her self at the horizon like a rabid rottweiller on steroids who's seen a bunny rabbit 2 miles away.
FM. Scared meself silly. Wheelspinning, having to change gear like a loony cause she's spinning up so fast then hitting the powerband and being pushed back in the seat. Honest I was glad to shut the garage door and walk away for a beer and a lie down. I'm sure I could hear her barking as I walked away... Probably saw a cat on the horizon....
I had posted some google links to pictures but its trying to log in as me
« Last Edit: 16 September 2019, 20:14:54 by MikeyBikey »
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #32 on: 16 September 2019, 20:16:57 »
looks like a nice conversion, although I reckon theres space for another one in front. That would be proper quick.
« Reply #33 on: 16 September 2019, 20:20:25 »
looking forward to pictures  :y
MikeyBikey
  • Cornwall
« Reply #34 on: 16 September 2019, 21:12:17 »
« Last Edit: 16 September 2019, 21:18:49 by MikeyBikey »
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #35 on: 16 September 2019, 21:26:52 »
looks like great fun  ;D
MikeyBikey
  • Cornwall
« Reply #36 on: 16 September 2019, 21:33:51 »
Thank you dave, how did you do that?
The sprinting pictures were with the essex 3.0 fitted and 150 bhp. Now I've got the y32se I'll have to grow some...
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #37 on: 16 September 2019, 21:42:27 »
above the first smiley is an INSERT IMAGE tab, (looks like a picture Frame)
insert the image url between the pair of ][
if you click quote on my post with the pictures, you'll see the text  :y
anyway, fantastic project
I'm from Tamworth originally and have a soft spot for all things Reliant  ;)
keep us posted on progress  :y
456lbft
    • Omega MV6-Fred
« Reply #38 on: 08 October 2019, 13:36:02 »
A very tidy installation, and a great use of a Y32SE.  I hope you sort the mapping and driveability issues, so you can enjoy it without scaring yourself!
Carlton 3.6 Track Car
Omega 3.2 MV6 Fred
MikeyBikey
  • Cornwall
« Reply #39 on: 26 May 2020, 22:15:20 »
Hi All, apols been a while since an update. Its been an odd year with a couple of attempts to move house being thwarted and a family relocation so this has been a project run in parallel to life at the mo.
What hasn't helped is a lot of teething problems with the drivetrain. And then once it was sorted  I've destroyed the engine, i think. So i'm after some pointers re these engines, what can go wrong etc please.
After a recent reinstallation of gearbox / clutch went for a spin. Parked up at Asda, some odd noises from clutch / gearbox region. Came out of the shop, the engine sort of started then died withmore unnattractive noises. Had to get towed home. After a lot of investigation (mostly on drivetrain !) I did a compression check.
Cylinder 1 - 50psi
Cylinder 2 - 0
Cylinder 3 - 0
Cylinder 4 - 0
Cylinder 5 - 50
Cylinder 6 - 250 psi (yes 250)
Cam belt good (new last year, tensioners good. Cams all good. not snapped etc.
Oil clean, no water loss.
Its out now and gone to the engine man but its frustrating. It was a low mileage engine  :( . I have a spare but with 167000 miles)
So any ideas what might cause that sort of failure ?
(PS the drivetrain issues turned out to be the flywheel not being true . This is now resolved)
cheers
« Last Edit: 26 May 2020, 22:17:00 by MikeyBikey »
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #40 on: 26 May 2020, 22:30:52 »
Is valve timing correct?, these engines are tough as nails  and can take a thrashing,all the police forces who used them will testify to that. I personally wouldn't spend much on the busted one,just fit the spare you have and hope you have better luck (167k should have plenty left in it) :y :y
other rides
« Reply #41 on: 26 May 2020, 22:34:43 »
Agreed, short of the belt snapping at speed, they'll easily run to 300k+ with nothing more than 10k oil changes and 80k belt changes  :y
Also, new engines were less than £2k from VX, so don't go spending too much on a rebuild ;)
« Last Edit: 26 May 2020, 22:36:32 by Doctor Gollum »
MikeyBikey
  • Cornwall
« Reply #42 on: 27 May 2020, 08:05:34 »
Ok thanks, hopefully the engine man finds out the cause, just don’t want to repeat  ::)
MikeyBikey
  • Cornwall
« Reply #43 on: 27 May 2020, 08:23:11 »
Question re cams. The y32 that’s failed has all four cams giving the same lift, 10mm. Is that normal spec?
« Reply #44 on: 27 May 2020, 08:48:28 »
10.2mm from memory, its at this lift that the curtain area is equal to the port area so optimum.
Did the engine over speed when the clutch let go as that's classic timing jumped and bent valve symptoms?
Pages: 1 2 [3] 4 5 6 7 8   Go Up
