Author Topic: Vista Question  (Read 2006 times)
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Vista Question
« on: 23 August 2008, 23:18:14 »
My clock loses time.
So I have gone to change the settings on the clock, internet time but everytime I try to update it says "an error occurred while windows was synchronizing with time.windows.com"
Anyone now why or whats wrong? :-?
Taxi_Driver
Re: Vista Question
« Reply #1 on: 23 August 2008, 23:22:17 »
Ummm your not connected to the internet?  :-/ ;D
Taxi_Driver
Re: Vista Question
« Reply #2 on: 23 August 2008, 23:23:37 »
PS time.windows.com works for me on XP  :y
Bandit127
Re: Vista Question
« Reply #3 on: 23 August 2008, 23:41:03 »
Try a different server. My XP used to need NIST.
http://itsvista.com/2007/01/itsvista-tip-17-is-your-vista-on-internet-time-mine-wasnt/
If that doesn't work, it could be a firewall issue. I don't know what port is used, but I doubt it's 80.
Re: Vista Question
« Reply #4 on: 23 August 2008, 23:42:09 »
Can you set it manually?
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: Vista Question
« Reply #5 on: 23 August 2008, 23:48:44 »
Yes but it is a pain in the arse, just wondering why it would do itself?
Re: Vista Question
« Reply #6 on: 24 August 2008, 00:05:48 »
I have known computers lose time when turned off due to failing cmos batteris.
HolyCount
Re: Vista Question
« Reply #7 on: 24 August 2008, 10:25:51 »
I have recently "upgraded" to Vista --- hate it !!!!   My computer clock is spot on -- but the display clock ( widget on my desktop) picks random times whenever I switch on and will not be altered !!!!
Whilst talking about Vista ---- does anyone run it with a Dymo Labelwriter hooked up? I have tried downloading the vista patch from Dymo -- but it still won't co-operate. Powers up and the comp recognises it -- just won't print !!!
Re: Vista Question
« Reply #8 on: 24 August 2008, 15:44:59 »
How wrong is the clock Loo Knee?
I believe if the time from time server seens inplausible (to current time) it will fail.
Also check firewall is allowing udp 123
Re: Vista Question
« Reply #9 on: 24 August 2008, 15:45:44 »
Other than the fact its different, why do you hate it?
HolyCount
Re: Vista Question
« Reply #10 on: 24 August 2008, 16:27:48 »
Really mainly a question of getting used to it I guess --- apart from that had to download patches for nearly everything I run. Some worked, some didn't.
Re: Vista Question
« Reply #11 on: 24 August 2008, 16:32:33 »
Apps older than about 3yrs that haven't obeyed the Win32 programming rules will need patching.  Drivers are an issue, but now its been out nearly 2 years, virtually all stuff, except really old hardware, should be supported.
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: Vista Question
« Reply #12 on: 24 August 2008, 17:10:26 »
used to be a old Poweredge at work that ticked backwards
Dell could never fix it!!!!!!!!
Re: Vista Question
« Reply #13 on: 24 August 2008, 17:30:18 »
Not that Dell use their own technicians, but they would fix it eventually. They'd probably end up swapping the server out completely though.
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: Vista Question
« Reply #14 on: 24 August 2008, 17:48:53 »
It seems it was a day behind for some reason  :-?
I have put it to the correct day and it updated with synchro ::)
Thanks everyone :y
