Author Topic: knocking from gearbox. renualt espace  (Read 1901 times)
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« on: 24 August 2008, 18:56:55 »
mate has a j plate (92) espace that gives a thump that is progressive with speed. dip the clutch & it goes away. any idea`s, is there a common fault to look for. :-/
Re: knocking from gearbox. renualt espace
« Reply #1 on: 24 August 2008, 19:22:42 »
Moving to general chat, as not Omegas
HNO3GOH
  • Somerset
  • Play time.
« Reply #2 on: 24 August 2008, 19:37:57 »
Sounds very much like drive shaft when it's under load.
The Red Baron
« Reply #3 on: 24 August 2008, 19:46:14 »
sorry TB didnt think.  ::)
Omegatoy
  • UK
« Reply #4 on: 24 August 2008, 20:46:43 »
bet it has a DMF and its 'dangle berries'ed!!!??? :y
The Red Baron
« Reply #5 on: 24 August 2008, 20:53:52 »
ok, i may be stupid but whats a DMF.  :-?
Omegatoy
  • UK
« Reply #6 on: 24 August 2008, 21:16:32 »
Dual mass flywheel mate, if its knocking it gone out of balance hence 'dangle berries'ed!! may not be it tho but usually if you dip the clutch and the noise disappears it is!!!
The Red Baron
« Reply #7 on: 24 August 2008, 21:25:07 »
surely if it was the flywheel then you would have the knocking all the time. or is it summat that only appears under load. :-/
Omegatoy
  • UK
« Reply #8 on: 24 August 2008, 21:28:50 »
depends on how bad it is, take it you have checked obvious things like driveshafts etc before posting?
The Red Baron
« Reply #9 on: 24 August 2008, 21:39:48 »
def not shafts.
« Reply #10 on: 24 August 2008, 21:46:29 »
No DMF on an espace of that ilk.
Engine mounts ok?
The Red Baron
« Reply #11 on: 24 August 2008, 21:52:51 »
had new mounts & support brackets. new tre`s, ball joints.
