Author Topic: are Driver and passenger window winder motors the same for all years?  (Read 3379 times)
addy
  • County Durham.  UK
    • 2.6 CD Saloon 2ltr omega
Sorry if in wrong section. Please could admin move it if it is. Thank you.
Could someone tell me if the window motors are the same drivers and passenger side front, through all the years? I have some later doors to fit on a 1995 Omega, and thought I might be able to use the motor on it, instead of having to take the one off the original doors. I have the wiring looms off the 1995 doors.
Thanks in advance for any help.
Addy
Drives 1995 2.0ltr CD Estate.  2002 2.6 CD saloon
I put FL doors on my MFL, and never swapped electric windows over
addy
  • County Durham.  UK
Thanks The Boy. Will fit door and connect motor. Shame the central lock motors aren't the same through out the years.
Addy
MonzaGSE
  • Norway
    • 95 Opel Omega mv6
Different connector on 94/95 cars. Slightly oval connector on both window motor and central lock. More square connector from 96 and up. That said the pin layout for the connectors are the same. A 94/95 car can use both type og central locks and electric window motors because the older style oval connector slides in nicely in the newer window motor or central lock. Connector wont «lock» properly but ive done this many times and never had one fall apart.
So:
-older door loom can handle both old and new type central lock/window motor
-newer door loom can only use new type central lock and window motor.
Addy
Mostly the same.  As MonzaGSE says, its only the very early cars that are different.
addy
  • County Durham.  UK
sorry to bring this up again. I bought complete doors including all the electrics from a 2002 omega. They are going on a 1995 omega, can i just fit them using the powercable already on them,or is is better to use the 95 ones? I used the 95 harness one on drivers door, but left the later door lock and window motor on, which work ok there was a small black piece in the motor connectors, once that came out the 95 harness locked in perfect. Just trying to save time if can do it that way. Or are the pinouts on the door pillars different for each facelift?
Thanks again for any help.
Addy
Use the cables from your original doors :y
addy
  • County Durham.  UK
Thanks DG for the reply. Just hoped i could have been lazy ;D
Addy
