Author Topic: Vectra aircon working poorly  (Read 3151 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« on: 16 July 2019, 09:17:55 »
My 2008 101K miles Vectra has failing aircon. Code reader reads aircon pressure 0.3 volts and 100kPa. Is it worth having it regassed?
Re: Vectra aircon working poorly
« Reply #1 on: 16 July 2019, 09:24:57 »
The car is over 10 years old, it'll have lost gas. Only you can decide if you can/want to spend £50 on a re-gas to see if the system still works  :y :y
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #2 on: 16 July 2019, 09:27:22 »
« Reply #3 on: 16 July 2019, 09:33:54 »
This ATS deal expires soon, but maybe of use to you  :y
http://www.groupon.co.uk/deals/ats-euromaster-ltd-20?utm_campaign=UserReferral_mih&utm_source=undefined
Book this via Topcashback and you get an extra 12% off!  :y
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #4 on: 16 July 2019, 10:17:43 »
Condenser.
Hoof'land storeman.
« Reply #5 on: 16 July 2019, 10:29:44 »
Condenser.
This. Although a regass might work, at 100k miles it will be due the radiator. We had three in our taxi fleet and they all started leaking within 500 miles of each other
Change the radiator whilst you're there.
Both a 45 minute job without jacking* the car... With a pit, even less time as they drop out from below :y
*raising the front slightly to improve access doesn't hurt, but with a pit, no need.
« Reply #6 on: 16 July 2019, 11:27:41 »
Incidentally, the radiator was £100 or so from VX, certainly considerably less than an Omega one :y
ronnyd
  • Online Online
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #7 on: 16 July 2019, 19:24:38 »
Had mine done a few weeks after i bought it, (due to it being the dead of winter when i first got it so too cold to check it worked properly). Guy who tested it said system was empty of refridgerant but system was not leaking. Also pressure wouldn,t settle on test but kept climbing so he had to stop the test. :D Anyway, decided that i would save the planet ::)  and not bother to keep slinging parts at it. So far just open the windows at start up to let the heat out and go from there. :y
biggriffin
« Reply #8 on: 16 July 2019, 20:26:35 »
Sounds like expansion valve.
Hoof'land storeman.
« Reply #9 on: 16 July 2019, 21:13:46 »
I could manage without air con, but my dog certainly couldn't. I have icicles on the end of my nose at the front, but the dog is still panting in the back.
ronnyd
  • Online Online
« Reply #10 on: 16 July 2019, 22:27:29 »
Yep griff, thats exactly what he wrote in the report he gave me. :y
