Author Topic: Error Code P0713 Transmission Temperature Sensor  (Read 2660 times)
Smiler174
  • Orpington Kent
    • 2.6 v6 Omega
« on: 23 July 2019, 11:09:27 »
Hi
Have Error code P0713 as pending and my car when accelerated hard will die a death, car drives fine but very slow acceleration, and when sport button used on top of shift stick is used it splutters like mad, also auto gear shift is random and harsh
Anyone have any advice on this and location of sensor
Thanks
Steve
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: Error Code P0713 Transmission Temperature Sensor
« Reply #1 on: 23 July 2019, 12:46:12 »
check the trans fluid level, there is a guide, before swapping sensors etc  :y
« Reply #2 on: 23 July 2019, 18:00:44 »
From memory, that code is Incorrect Ratio?  If so, check fluid level, but its probably too late.
« Reply #3 on: 23 July 2019, 18:05:24 »
Ignore my memory, its shit ;D
P0713 is fluid temp sensor voltage high.
Caused by:
The voltage at the control unit input (terminal 22 ) is greater than 4.92 V .
Above condition must be fulfilled for at least 2.66 s .
Smiler174
  • Orpington Kent
    • 2.6 v6 Omega
« Reply #4 on: 30 September 2019, 12:56:09 »
Anyone got a guide on sensor change
