Author Topic: Aircon ceased to work. May I rmove the plumbing?  (Read 6860 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« on: 28 July 2019, 10:02:33 »
2006 Astra 1.6 petrol manual
I am replacing the hose from water pump to radiator and header tank. Access to the radiator connection is poor. Is there any reason why I should not saw out the aircon hose?
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Aircon ceased to work. May I rmove the plumbing?
« Reply #1 on: 28 July 2019, 10:05:28 »
Because when it gets bloody warm, you'll be moaning for not having air-con.
Hoof'land storeman.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #2 on: 28 July 2019, 10:45:49 »
There must be a better way of doing it.
terry paget
    • 3 Astras 2 Vectra
« Reply #3 on: 28 July 2019, 11:20:19 »
There must be. I can see the clip from below, but it's a spring clip and the ends are inaccessible. I thought I might angle grind it off, but space again is the problem. I could remove the front bumper I suppose.
« Reply #4 on: 28 July 2019, 11:28:07 »
Front bumper practically falls off the newer cars ;)
Also, if it's anything like the Vectra C, you undo two bolts beneath the radiator and drop it down before disconnecting it :y
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #5 on: 28 July 2019, 11:43:43 »
Have you got a dremel or die grinder Terry  :-\
that you could cut the hose clamp with ? replace it with a jubilee clip after
I've ripped all the AC out of an astra G before but these newer Can-bus astra H cars are not happy when you remove sensors  ::)
  • Chatham, Kent
« Reply #6 on: 28 July 2019, 11:51:24 »
You need one of THESE although other suppliers have them. Access problem solved. A SET is even better if you're going to working on vehicles afflicted with spring clamps.
You know I replace the bloody things with proper worm-drive clamps, but if you do that you also want the long flexible driver meant for such things; Halfords sell those, complete with an interchangeable socket so you can use it on both 6 and 7mm hex fittings.
« Reply #7 on: 28 July 2019, 12:20:55 »
Spring clips are the work of the devil.  ::)
biggriffin
« Reply #8 on: 28 July 2019, 12:44:09 »
Why not just fix it, I know it might involve new parts, but I know what I would do.
Hoof'land storeman.
terry paget
    • 3 Astras 2 Vectra
« Reply #9 on: 28 July 2019, 16:07:26 »
Why didn't I think of that? I found my cable operated hose clip tool, and it worked a treat. I also had a flexible jubilee clip tool. Job is now done, and car returned to Ben, who is taking it on holiday next weekend. Thanks to all for advice.
Another job jobbed. :y
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #10 on: 28 July 2019, 16:09:46 »
"OK , that's fixed , on to the next one "  ;D
well done Terry  :y
« Reply #11 on: 28 July 2019, 17:33:56 »
For info, a common aircon failure on these is a thermal fuse in the compressor clutch going open circuit, you can get a kit for about 40-50 quid which allows repair.
Be also careful, as a result of the above the aircon system can still be fully gassed even if it doesn't work!
« Reply #12 on: 28 July 2019, 17:40:31 »
What is an average cars air con system pressure Mark?  ???  :-\
« Reply #13 on: 28 July 2019, 17:42:35 »
About 30psi
« Reply #14 on: 28 July 2019, 17:46:33 »
That's the first answer I found on google.  ;D
